Mine used to do this too. It would just randomly blink quicker than normal, as if a globe has blown, but once you take a turn, it would return to normal. I too have a 32 sedan.
I think it's been a loose connection or a faulty globe though.
I normally get this issue after blowing an indicator globe. However (once) I needed a new universal timer thing that controls the indicator timing, I can't remember the real part name....except that it was about $15 and bought from Bursons or Autobarn.
  • 3 months later...
  • 4 weeks later...
Hi, hope I don't cause bad bumpage of this thread, though I felt it was better to have it in the same spot than start a new one.
This morning my indicators started doing the same thing, just on the left side.
I haven't had the chance to check it out thoroughly yet as I just got to work, but it's only the front left on the front bar that isn't working.
If I put hazard lights on, they all blink at the usual rate, but still not the front bar left indicator.
Is this a normal thing to happen when an indicator globe goes? Or could I expect it to be something else? It's only happened this morning..was kinda scary in traffic when you can only see the reflection of one indicator and not knowing if people know your intentions with turning =S
Also for the OP. Your car being a sedan doesn't mean your car shouldnt have side indicators. As far as I know its actually something that is meant to be done at compliance to comply with Australian standards.
I gather this isnt harshly controlled as their is a lot of imports missing them. But saying that, I have seen plenty of sedans with them.
Have you checked you have side intrusion bars lol?
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
