im a casual but working more shifts than a full time
= awesome money, at least you can afford to buy a system LOL i have to stay with stock for a while bahaha go the DVD/TV duo with some good speakers, no need for subs or anything IMHO
just my2c
Andrew :(
Here is a different angle on why you could/should get a DVD deck over MP3 Deck.
My last GTR had a Haltech e11v2 which comes with software (to display in real time) gauges for engine vitals (i.e. boost, air/fuel, etc...) on a computer screen/PC setup.
I investigated further the concept and found out you can buy "car PC's, basically small boxes that house a computer with a A/V video out to your DVD Deck. You can also use a bluetooth keyboard/trackball mouse combo (cheap these days) all running of 12v....!!
These days you would just have a 8GB usb key as the storage device for the PC to load windows from.
This setup will negate the need of aftermarket gauges, you wont get pinged by the boys in blue for having gauges above your dash. Also you can have your screen open all the time displaying engine vitals with warning lights on the screen etc.....
I did not ending up doing it as buy that time I sold the car.
If anyone is wanting this type of setup, I will be happy to provide advice on setup, etc.....
Edited by im late
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
