hey dude i'm in vic and i just recently did the same conversion in my 32. i just told them i blew up my old engine (rb20det) and had to put a new engine in (rb25det). All they asked for was the recipt for new engine and to veiw the engine number in the car (to make sure it wasn't a stolen engine, i would imagine). Oh and i just said it was the same sort of engine to avoid questions about having a bigger engine.
https://www.sau.com.au/forums/topic/218843-25-powerd-32/#findComment-3860767
So did they pull you up on the engine number, because you saying that its an rb20, with an engine number rb25xxxx is likely to get you in trouble. its an increase in power and capacity so most of the time you need an engineer's cert. but thats just in vic, cant comment on other states.
https://www.sau.com.au/forums/topic/218843-25-powerd-32/#findComment-3861820
Nah not at all, 20 or 25 same thing to a stock person haha. you have to remember that 99.9% of people wouldn't know that r32gtst's come standard with rb20det's and r33gtst's come standard with rb25det's. so unless the person viewing the engine number is a mechanic that knows alot about skylines then i'd think you'd be pretty sweet.
https://www.sau.com.au/forums/topic/218843-25-powerd-32/#findComment-3864212
It worse than that. 'Stock' people (what, like they're friggin' cattle?) wouldn't know what the noise is coming from under the bonnet.
https://www.sau.com.au/forums/topic/218843-25-powerd-32/#findComment-3864247
Soon as an officer pulls you over - off the road you'll go with the illegal engine conversion :P
Police know what it all means. And can see if you've been engineered or not, if you haven't, bye bye :(
I know quite a number of people who've been instantly put off the road for that kind of thing.
https://www.sau.com.au/forums/topic/218843-25-powerd-32/#findComment-3864411
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
