I was doing some maintenance on the weekend and when I had a close look at the radiator and heater hoses I noticed that they are probably the same ones that have been on since the factory. I gave them a squeeze and I could hear them cracking on the inside and they were really soft.
I figure it's worth changing the lot now as it's not worth the risk of one failing, would probably need a new engine. Preventative maintenance is a lot cheaper.
Has anyone else had any experience in this? I asked if they had radiator hoses for an R33 at Autopro but they said no. Will I have to order them from Nissan? Does anyone know where I can get them from?
I can change the radiator hoses myself but I'm not sure about the heater hose. I tried tracing it back and it looks like I may need to take the manifold off to get at it. Has anyone attempted this before? or would you advise getting a mechanic to do it.
I also would like to know where I can get a radiator cap, I haven't tried any auto shops but the one on there looks smaller than standard, I think it's rated 0.9 kg/cm2.
Thanks in advance.
Matt
https://www.sau.com.au/forums/topic/21902-radiator-and-heater-hoses/
Heater hose runs along the back of the engine bay, up against the firewall. If you look behind where your turbo is you should see to pipes going into the firewall, one of them should have some heat shielding (I think) on it. If you follow it back it ends up on the manifold side down to the rear left hand corner of the engine (I think).
I'd investigate R31 radiator heater and radiator hoses, should be fairly close close I'd say. Just take one off, go into the shop and see whether they can find a match.
The only time u might find it hard is if you have some special one that needs to wrap around your FMIC piping (if you have one)
Ask your local nissan dealer for a radiator cap, they will probably be able to get you an equivalent. I lost(dont ask how..) the cap to my radiator overflow bottle, and it happens to be the same one as used on nearly every nissan since 1994 according to the dealer. So yeah it was $12...ask about the radiator cap..
u should be able to change ur heater hoses without removing the manifold , i haven't looked in the gtst but i have done it in the r33gtr its hard to get to but doable .
if the hose doesn't have sharp bend in it u may be able to use normal straight hose but if its short and with 90 degree bend u may have to get it from nissan or u may be able to get it from auto 1 , supercheap or other aftermarket resellerl
I got a high pressure nismo radiator cap from UAS in sydney a while back!! should give them a call see if they can get one for you, haven't seen one in stock lately!!
they have replacement silicon radiator hoses too, but not too sure about heater hoses, might find out myself actually!!!
hope this helps
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
