skyryan ATWELL represent i went to primary school with your bro
yeah i dont think it will be long till it blows
its surging at idle but only in drive and neutral(its auto)
no idea what it is
i have reset the ecu to no effect
runs perfectly above idle on and off boost
so with the oversized pistons should i wait to get the rebuild kit after the motor has been machined
so i can see what sizes i need
or would most machining places bore the block out to a requested size even if its not needed?
cheers
  • Replies 51
you may want to look at strengthenin the auto box or a shift kit
you building it yourself? or is a workshop/machine shop assembling it?
id imagine they can just do it without the actual pistons and just the sizes
build a rb25/30 :) torqe ftw!
spoolimports.com has a fair few piston/rod packages
and Sydneykid has used them pumping 500rwhp+ and still running
i am very much leaning towards a 25/30
ill get it done at a shop
any recommendations
a workshop i found has a kit for a 25 $5120 for parts plus labour which that said 1500-1800 depending on the condition of the head
sound ok???
was thinking of manual convertion
or shift kit and oil cooler and some strengthening
havent really researched gearboxs in depth yet
breakdown of the parts? and there individual cost?
labour sounds right, does it include cams?
and i dont think the rb25 pistons would fit a rb25/30
and im sure spools rods r cheapest forged items you will find $645 a set
be fare to say once u get a new turbo, manifold, engine rebuild, ecu and tune
you wont get much change out of 10k
nah no cams
no individual prices
STAGE 1 $3205
cp pistons and rings
eagle H beam conrods
genuine nissan gasket kit
tomei metal head gasket
tomei assembly lubricant
STAGE 2 same as 1 plus
genuine nissan n1 water pump
gates timing belt
$3705
stage 3 plus
ARP head studs
ARP main studs
ACL race main bearings
ACL race conrod bearings
$5120
hmmmm you might as buy one of those rebuild kits off RACESPEC hes a sponsor for the forums and he sells kits for the RB25 which includes CP Pistons, Rings and Rods for 1850 so that saves you a bit on parts and also the main studs and head studs you can get off RACESPEC or high octane racing their website is http://www.hioctaneracing.com.au/eshop/ so i hope that helps anyways :spank: but yeah it'd be cheaper if you buy the parts yourself :P
Cheers
Chi
on the cheap ftw!!
if there is a cheap way to rebuild an engine
definately gonna try to cut costs anywhere possible
but not cut quality
does anyone recommend somewhere or someone to build an engine
cheers matt
yeh fair few machine shops would be able to machine/build it
but u still need a workshop to wack on the turbo (if u cant do it urself)
ummm
u can source it WAAAAAY cheaper if thats w.o labour
check our CRD's package in the sponsor section
they have a nice deal goin on
man the CP package from RACESPEC is quality its cheap :spank: hehehe if u want quality and a price tag bust out some HKS, Tomei, Jun items :P pretty sure they'll make ur wallet lighter ;) but if ur after good cheap quality parts then yeah Hi Octane or RACESPEC is the go :(
Hi octane is over priced, 3.6k not including gst, thats closing in on 4k for
pistons, rings, rod, gasket kit, metal head gasket
RACESPEC is very similar to SpoolImports (10 bucks more for the 25 package)
RB25/26 - $1850.00
RB25/30 or RB26/30 - $2050.00
RB30 - $2050.00
SpoolImports
1. Package deal on 1 set of Spool RB30 H beam conrods with 1 set of Forged CP Pistons and rings. - $1990
2. Package deal on 1 set of Spool RB26/25 H beam conrods with 1 set of Forged CP Pistons and rings. - $1840
Both run CP pistons/some forged rods with ARP bolts
CRD
ARIAS Pistons
EAGLE connecting rods
NISSAN (Genuine) gasket kit
TRUST drag metal head gasket
TRUST camshafts
ACL race series engine bearings
Total price only $3599.00
Same price as Hi-Octane but u get cams and bearings (combined value around 800 more)
Dont forget all these "rebuild" kits
you need to factor in some of the following items if its not included
Gates timing belt $300
crank/main bearings 400-500
gasket kit $500~
Optional
Water pump $200
N1 or higher Oil Pump if your makin decent power $500+
ARP main/head stud kits 600-700
cant just throw in "forge pistons and rods" then go horray! 600hp ftw!
definatly gonna shop around heaps
the racespec ones seem okay
i read somewhere that the n1 oil pump is dodgey on street driven cars
something bout it cant pump enough oil at low rpm or something
not sure how true it is
how long would a rebuild take at a shop
taking into consideration other jobs and all that
cheers
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
