  • Replies 89
its actually not that bad better than most r33's ive seen it just needed some better wheels
The front bar is way to big, dont think wheels would fix it, if it was made smaller it would look way better, but im not a fan of aftermaket kits, but thats just my thoughts
just so people know this is the car im talkin about
I agree DSTROY, lower front lip needs to be reduced big time, and less twisties in the sides. but hey, each to their own! veilside are still in business arent they!
