I talked 2 my mate, and he said to do it the way Karl and Mine were done. Otherwise, go into any car stereo shop and they should be able to help you out.
Audiocom were about as useful as an arthritic baboon... :spank:
If you insist on putting 6x9s in, JB HIFI/Alberts/Westside etc will sell spacers for about $20.
Its either that or cut the parcel shelf.
Personally, I put 6.5 coaxials (same as 6x9, but round) in mine to get around using spacers.
I installed all my own audio gear, so if you want a hand, Im usually free sunday arvo (if your in Perth?? and not Kalgoorlie :spank:)
It isn't so much I insist, just my folks bought me some really nice speakers to go in the VL, I still got em, because they are a gift I feel like a sh*t bloke selling them, and not just that, I have seen skylines with them, so I know it isn't impossible, next time though, deft go 6.5 considering all the hassle...
I thought I was going to help you make it :D
lol. Its all good. We really couldn't be stuffed last weekend could we :D
With the way your shifts are going dude..
I won't see you for like... A month or something...
ok, too clear up 1 thing, drilling 4 little holes per speaker in the back shelf isn't going to weaken the structure any amount that you would even bother worring about, and if you were worried bout it well the make a doubler
What I care about is DPI regulations...
You may very well be right, and on engineering matters I trust you a lot (You know that)...
But yeah, if it is illegal I ain't doing it...
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
