hey guys,
i'm taking the car to the mech tomorrow morning. but just need some ideas quick
Took off to go to work bout 6pm, car is still warm as i only got home at 5.30pm, so no need to warm up the car
come out of my driveway, probably hitting 3000rpm ish, car goes POOOOP, i was like wtf. Then power starts cutting out(lights start dimming and going bright again), eventually the car stablises, idles at 1000rpm, then alll of a sudden the revs build up slowly.....from 1000rpm to 5000rpm. so i turn off the car
so i opened the bonnet to make sure my accelerator cable wasn't caught. everything looks fine.
turn the car on, car revs slowly up to 4000rpm again~!!!
then i turn it off, stepped on the throttle again.
and turned the car on again, this time it idled properly. at 800rpm ish.
so i put the car back in the garage, and go to work as i'm alrdy late.
come back 4hrs later
turn on the car, idles properly, so i tried to back it out. i reversed about 5metres, car starts acting weird again. i let it idle, and it idles hell rough with revs jumping up and down ( 800-1000rpm). and the car sounds like a rex
so i wait for 2 mins with he car on, then the car idles and sounds normal again.
tried to take it for a drive. the car feels hell weird, no power at all. so i tried to slowly boost it..but NO boost at 4000rpm..wtf..i can hear the turbo spinning making a weird sound...
then the car starts losing power again. it struggles to idles. then stallls...wtf
i can still turn the car on, but idles hell weird. doesnt have power at all and doesnt make any boost
so any suggestions? please, i need to know whats wrong lol. or i cant sleep tonight
coilpack? turbo? cylinder?
and btw lately when i take off slowly i can hear a very light 'hummming' noise from the engine, but never took notice of it
i also have a vented bonnet. but it's only vented on top of the radiator. so i assume it has nothing to do with it as water only goes to the radiator
so any suggestions plz/??
cheers
steve
sorry bout the long post, and it probably doesnt make sense.
https://www.sau.com.au/forums/topic/219402-wtf-my-cars-fked/
  • Replies 60
I had a air line come off the front of my motor, ran like shit , almost like on 5 cylinders.
Just go through everything around the engine, also you might have a dud Injector, been there....
I am around the corner, so If you wanted too I could come by and have a look....
Bit late now.
Mike
Hey Mike, which 'reputable' imports workshop is closest to innaloo? i wanna drive the car there instead of towing it
the one i usually used is like 20km's away so i dunno wanna drive that far
I looked on the 'The Consolidated Workshop Thread' and closest is 'Speedworks' in osborne park. but never heard of them
hmm, still sounds like a pipe has come loose, have had this happen to me a few times in silvia/skyline, exact same issue was due to a pipe coming off turbo, may look like it's on but.. air still may be escaping, doesn't take much when it comes to compressed air :spank:
    • Just a thought, was that car and auto at any point of its life? If so, maybe whoever bridged the inhibitor switch/circuit did a not so good job.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
