Item:Have my r33gtst for sale aswell as a half built rb26
Age:r33 1994 Rb26 bottom end is new
Condition:both good except the head on the 26
Price:$20,000 ono
Contact:Anthony on 0438774173
Comments:Recieved a 26 6 months ago pulled it down to see if it was ok and found that it wasn't so had to rebuild it. Just found after having the head machined that theres too much clearance in the valves and not suitable for my application, so with a $3000 bill from the machinest and whatever it will cost me for another head plus the $1000 on the port job im out of money. The whole lot is up for sale including all accesories turbo, gate, injectors etc...
MOD LIST:
Engine
N1 24U block (own modifications done) race prepped
Chemically cleaned/crack tested and washed
Torque plate bored honed & decked
All new welsh plugs
Tapped oil gallaries
Fully balanced/detailed crank and grub screwed
Race prepped crank gurdle
Shot peened/prepped standard rods with ARP bolts
Full ARP bottem end stud kit
Ross Racing forged pistons (ceramic coated)
ACL race bearings mains & rods
N1 oil pump (modified)
N1 water pump
Genuine Nissan gasket kit
Fully port & polished head
Match ported intake
Brass valve guids
Standard valves
Upgrade valve springs
Standard cams
Greddy adjustable cam gears
Greddy clear timing cover
Polished intake manifold and valve covers
Gates timing belt
New genuine exhaust studs & nuts
Garrett GT3082r turbo polished front cover
Braided oil lines
.82 & 1.06 housings ceramic coated
Tial 44mm wastage
Ebay spec manifold modified
Greddy twin entry air intake pipe
2 x RB25 Air flow meters
3.5" dump pipe
3.5" catback exhaust
600x300x115mm Greddy style intercooler
Custom PBR clutch
Nismo lightened flywheel
Nistune ECU
Sard fuel pressure regulator
custom fuel rail
044 fuel pump
2L surg tank
3/8" Aluminium fuel lines
Heap of speed flow fittings & push lock hose
Sard 700cc injectors
Alloy dual core radiator
Silicone radiator hoses
Silicone heater hoses
Car:
Milage: just clicked over 110,000km
Colour:white black bonnet
Currently registered?yes just renewed rego so has 6 months left
Interior:
Standard interior
Bride style seats
hybrid electronic boost controller
Silver Auto metre boost guage
Greddy turbo timer
New gear and handbrake boots
harness mounts on parcel shelf (removable)
Audio:
Kenwood double din with frequency enhancer
jbl splits up front
clarion splits rear
Body:
Full M-Sport kit
Black bonnet with ventDrift wing
18x8.5 fronts and 18x9.5 rears with 90% tread roh drift r's
tein coil overs
https://www.sau.com.au/forums/topic/219452-r33gtst-rb26det/
