I'm putting all these rumors to rest.....;
R33 GTST 1993, Manual
THIS CLUTCH WILL ONLY FIT AN OLDER TYPE SKYLINE WITH THE PULL TYPE CLUTCH ON YOUR SLAVE CYLINDER.
Now theres seems to a bit of confusion going on from the last posts about clutches.
Back in May my clutch went....I researched around and sourced a new clutch.
The clutch is rated at 1500kg, heavy Duty Daiken NISSAN PATROL CLUTCH.
This clutch is interchangable with my Skyline and is half the price nearly.
Different name on the box but its the same shit only different price.
The clutch was worth $300.00 from SLACKS CREEK BRAKE AND CLUTCH (See Geoff)
GAVIN WOOD installed the clutch and through out bearing & oil for $290
The feel of the clutch pedal is great. The position of the clutch pedal is great.........just like a new clutch is supposed to behave.
When I drive it hard it doesnt slip or do anything stupid.
I can drop the pedal at 3 g's and the back wheels light up pretty quick.
I highly recommend it if you have a mild to standard liner.
AND Its not 1.2 cm or 0.004mm off the floor !- Come on guys.
Any further poblems or questions u can email me; swordfish19792002 @yahoo.com.au
  • Replies 87
Very interesting! A couple of questions though - (1) When did Skylines go from the pull to push type clutch? (2) What is the standard clamping pressure of the normal factory clutch? (3) Can any Nissan dealer get these in for around that price?
JimX,
>>> I think 1995 onwards....double check with Gavin Woods, labrador QLD first.
>>> standard is 650-700kg
>>> Yes they can I think they were more expensiver of hand than Slacks Creek Brake & Clutch.
I tried Nissan on the Gold Coast and I think they were $55 more or something....Can't remember though.
Put get the part number first before u start ringin for prices.
swordfish u mean ur skyline has a push clutch dont u ? early mods have push late mods have pull my r33 gtr has pull ( the slave cil pushes to engine so it pulls the clutch away from it hence the name pull ) .
by the way all old cars had push and most late mod cars have pull
got my clutch done on tuesday;
been taking a bit of getting used to as its fully engaged about an inch of the floor;
liking it though, feels way quicker, perhaps the old clutch was slipping more than i though;
  • 4 weeks later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
