Ok, well i just took apart most of my boot lining to find the cover to the fuel pump. I pulled it of and it looks fair confusing for a person like me.
Anyone willing to help me install and look out for this "sludge" everyone keeps on talking about? Plus, if there were signs of this sludge, would i have to
replace my fuel lines and fuel filters??
I'd say the sludge would most definitely be related to a bad batch of fuel as I've owned my R32 since 2001 and recently dropped an 044 intank. The tank was 100% clean an the cars now done a little over 260,000km's in total.
I've only ever ran BP with the occasional tank of Mobil and recently Shell as its only 10c more compared to BP of which seems to charge 13c more :thumbsup:
044 intank Joel nice work.
you planning on making some more power soon or just a preventitive measure?
Ahh the 044 was fitted quite some time ago.. When I first mentioned I was having troubles as you may remember
I think 6 odd months ago? Cars done hardly any km's since then as I bus it in to work these days. Only driving it does is on the weekends so I can justify a bit of a lumpy idle and bad fuel economy.
The cams are ever so slightly larger than what your currently running.
Are you still thinking about WMI? I wouldn't mind getting a kit on before the next dyno day of which should be a reasonable turn out with some decent cars. Would be nice to crack 1rwkw more than what you did last dyno day. :thumbsup:
You really dont want to push too much more than 260rwkw out of a walbro.
Dangerman 4 will justify this and if you are aiming for more then you will want to look at an 044 which will safely push over 300 rwkw.
Ok. Well after nervously looking at the instructions on how to install the fuel pump tonight, i decided to do it. Yes it was easy to install and yes you do smell like petrol after.
Infact after a while with the petrol tank lid open, the missus told me i was speaking real fast lol XD but yeah i got a headache after a while...
I took her for a spin and yes it does run good now =) Even better then before.
Ps. I pulled out my old fuel pump to find it was a Bosch unit. How do i tell what model it is... It has a serial number of some kind which ends in 040... and also has a speed flow fitting.
Thanks Madaz. To be honest that was my first time installing anything on a car of that magnitude. I thought it was brave of me to throw my hands into the tank of petrol lol! But
it was worth it. I also found out that i have a GTR fuel tank... which was random.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
