  • Replies 46
Posted Images
No I have no diodes.. it is a very basic setup. I think the reason it was staying closed was because the pump was stalled.. if it runs i'm sure this will not be a problem as it does when running 12V.
The current/voltage relationship depends on whether the pump is loaded/unloaded or stalled.. the current and voltage will only increase proportionately to each other in a stalled condition (IE back EMF constant).
In a loaded condition the current will remain fairly constant with voltage change as the back EMF will also vary as the pump speeds up or slows down. If you had no regulator or friction in your fuel line, varying the voltage would do very little to the current draw however.
Sure if you increase the voltage the current will also increase slightly when the pump is loaded but not proportionately. If the pump goes from running at a set voltage and suddenly stalls. For that same voltage you will see a large spike in current. This was the concern.
With your V=IR you are not considering I=(V-E)/R where the real voltage (potential difference) across the windings is important. (E = Back EMF)
The pump resistance may be fixed, but the back EMF changes. If this back EMF hits 0 (Stalled pump) the current seen at the pump will then become input voltage x coil resistance = huge current and a burnt out pump...
A voltage divider is a standard way of reducing a voltage. They use two resistors with different values and the voltage output is determined by the ratio of resistance values of these two. They are in series but the output is taken out between these.
The GTR module is not as simple as a resistor voltage divider as it drives a fairly large load. Usually resistor voltage dividers are used for signal currents only. (IE milliamps)
I have looked at the method you described of adding a bypass around the 044, but it seems silly to add yet another pump when this one will do 800HP on it's own. Why add more when you can slow the pump.. a PWM motor speed controller will do this perfectly.. without reducing voltage supply to the pump.
So I don't think it's all as simple as people are adding here.. and I am fairly confident my setup will work fine with a few tweaks :)
Update:
Seems to work a treat. Problem is now that my internal GTR pump running with no pressure against it is now louder than the 044 at 7V..
The 044 kicks in to full voltage at around 2.6V and off at about 1.4V. Took it for a drive around the hills and this seems perfect.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
