CHI100188
I currently have the dual port BOV from Turbosmart on my series 2 r33 and also have the turbosmart r33 adapter and the plumb back adaptor. i spent roughly $150 on the two adaptors, but knowing those adaptors will fit the r33 perefectly i would recomend buying the genuine turbosmart ones, instead of make your own or getting some made for you. i can post a pic for you and show you what they look like if you want.
https://www.sau.com.au/forums/topic/219985-bov-adapters/#findComment-3880417
i hope so :thumbsup: hahah hmmm just a question? u know the thing that blocks off the return pipe did that come with ur bov? or does that come wiht the adapter kit?
Cheeers
Chi
i think it came with the bov but if you have the dual port doesn't it plug into there?
https://www.sau.com.au/forums/topic/219985-bov-adapters/#findComment-3880547
Ok well the FG-ADM-R33 adapter kit will get the BOV on to your car, but it will be only venting to atsomphere which will cause you a little bit of grief with stalling issues. Please refer to the documents that i have attached. with the FG-ADM-R33 you will be able to follow up until step 9, then you will need to refer to FG-ADM-R33PBK. Hope this helps clear things up for you. :teehee:
FG_ADM_R33PBK.PDF
FG_ADM_R33.pdf
Edited by jonzie26
https://www.sau.com.au/forums/topic/219985-bov-adapters/#findComment-3880706
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
