Item: JVC KW-AVX700
Website: N/A
Item Condition: As new (less than 12 months old)
Reason for Selling: Never gets used and cars coming off the road again
Price and Payment Conditions: $700ono
Extra Info:
Pictures: below
Contact Details: PM or email [email protected]
Features
Highlights
# Power Output: 50W x 4 Max.
# MOS-FET Power Amp
# Built-in 6.5-Inch Wide Monitor
# SD Card Slot
# GIGA MP3 MULTI
# 192kHz/24-bit Audio DAC (DVD-Audio)
# 7-Band iEQ
# Ready for iPod®*
# DVD-Audio Compatible
# WAV Compatible
# MP3/WMA Compatible with ID3/WMA Tag
# JPEG Playback
# DVD-R/-RW, +R/+RW, VCD Compatible
# Multi-Border DVD Compatible
# CD/CD-R/CD-RW Compatible
# 5.1-Channel DTS/Dolby Digital/Dolby Pro Logic II/2ch MPEG Decoder Built-In
# Time Alignment (5.1ch)
# Gold-Plated Line Output Terminals (x 2 pairs)
# Gold-Plated Center-Channel Output Terminal
# Gold-Plated Video Output Terminals
# Gold-Plated Subwoofer Output Terminal with Level/Frequency Control
# Second Gold-Plated Audio Output Terminals
# Gold-Plated AV Input Terminals
# AV-BUS Input
# Motorized Slide-Out Face
# Multi-Function Wireless Remote Control
# Dual Zone Function
# Headphone Surround
# Shock Proof Memory
*In conjunction with KS-PD100
DVD/VCD Section
# Video Format: NTSC/PAL
# Zoom (for DVD)*
# Chapter Access (for DVD)*
# Pause/Step/Slow*
# VCD Playback Control
# Direct Track Access (for VCD)*
# Last Position Memory
*Remote control only
Monitor Section
# TFT Active Matrix LCD with Wide Viewing Angle
# 280,800 Pixel Resolution
# 16:9 Aspect Ratio
# Selectable Angle
# Aspect Select
# Switchable Dimmer
# Power Switch Standby Illumination
iPod® Control Section*
# Play/Pause
# Skip/Search
# Random/Repeat
# Text Display
CD Section
# CD Text
# Disc Name Registration
# Direct Track Access*
# Random/Repeat Play
# Intro Scan
Changer Control Section
# MP3 Control*
# CD Text*
# Intro Scan
# Skip/Search
*In conjunction with CH-X1500.
Tuner Section
# HS-IV Tuner
# IF Filter
# 18 FM and 6 AM Presets
# SSM (for FM)
# Seek (Up/Down)
# AFNS/PNC
# Stereo/Mono Switch (for FM)
# Auto Antenna
Amplifier Section
# High-Pass Filter ON/OFF
# Source-Specific Volume Control
# Balance/Fader Control
# Volume Attenuator
# Max. Amp Gain Switcher
# Amp Defeat Switch
General Section
# Tel. Muting
# Beep Tone Support
# COMPU PLAY
# Power-Off Mode Eject
# Preferred Setting Mode
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
