Hi guys,
Recently ive realised that my cars been making funny noises especially in the cold morning when turning the car on for the first time of the day. Problem is i don't know whether this sound was always there or not cuz its really not THAT loud enough to hear from inside the car.
What happened was, i was doing an oil change so my bonnet was open then i turned the car on to let the oil circulate, then when i turned it on i hear this short "crunching" sorta sound from the passengers side whereabouts the a/c thing is but couldn't precisely locate where its coming from. It happens everytime i turn the car on and on and slowly goes away till when the engine is completely warm. So please could anyone help with some suggestions or have had similar issues like mine and tell me what this is?
I would appreciate it alot as im in a tight budget go actually go see a mechanic for this at the moment as my rear bars been hit and need repairs :D
Cheers
https://www.sau.com.au/forums/topic/220337-need-help-please/
To give abit of info to those with GTT R34:
- It usually makes a similar sorta noise when turning the climate control knob from high/low but its from the dash that i hear it.
- The issue is i hear it under the bonnet so i lift the bonnet up and try looking for the noise and its whereabouts the BOV is
What im again curious about is, could this come from the same matter? Anyone have these climate control sounds? then similar when turning car on?
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
