APEXi products brand new from the Sole Australian APEXI Agents - Warranty and Tech Support
Brand new in box APEXi Power FC Units with Hand controller
Nissan Skyline R33 GTS-t (brand new) - $1650 delivered
Nissan Skyline R34 GTT (brand new) - $1540 delivered
Nissan R32 GTS-t AP Engineering FC (brand new) - $1650 delivered $1950 (with controller) delivered
Nissan Silvia/180sx CA18DET AP Engineering FC (brand new) - $1650 delivered $1950 (with controller) delivered
Nissan GTi-R AP Engineering FC (brand new) - $1650 delivered $1950 (with controller) delivered
Universal APEXi Power Intake Pod Filters
Universal Bolt up pod. Dry type pod only need compressed air to clean.
Available in -
OD 160 ID 85 (REPLACEMENT FILTER) - $89 delivered
OD 160 ID 75 (REPLACEMENT FILTER) - $89 delivered
OD 160 ID 65 (REPLACEMENT FILTER) - $89 delivered
OD 140 ID 75 (REPLACEMENT FILTER) - $89 delivered
APEXi Power Intake Panel Filters
Replace factory air filters with greater filtration and no need to replace just clean!
Available for all popular Nissan models and other manufacturers - $79 delivered
APEXi Power Intake Filter Kits -
pictured is R33 R34 GTR kit
Nissan GTR Skyline R32, R33, R34 Kit - $350 delivered
pictured is R33 GTS-t kit
Nissan Skyline GTS-t R32, R33 & R34 GTT Kit - $140 delivered
**Other Nissan vehicles available as well as other Manufacturers
APEXi DECS Tacho -
Main Features Include:
- Large, 120mm analog display for easy to read shifting points.
- Digital display built into the gauge face
- Classic EL (Electro-Luminescence) lighting
- Accurate RPM reading all the way to 11,000 RPM
- Progressive number design for better high RPM viewing
- Integrated TEMP, and Pressure reading*
- High intensity shift light included
- Versatile mounting bracket
- Available in white and black face
- $590 delivered
* Temp, and Pressure reading available only with the use of an optional Temp or Pressure sensor. Sensors sold separately.
  • 1 month later...
  • 1 month later...
Any Power FC's for r34 gtt? If not do you have any coming in and is it possible to put a deposit down for one?
I have a small handfull in next week monday
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
