Make: Nissan
Model:1997 R33 S2 GTS-T
Milage:just past 100k
Transmission:manual
Colour:White (QM1)
Complied?Yes
RWC supplied?No
Currently registered?12 Mths rego
Price:$15000
Contact:Adam 0416 598 050
Comments / Modifications:I'm the second owner after it was imported. I've owned it for two and half yrs, when i bought it it had 3inch exhuast from turbo back. Since i've had it i've put a new high flow cat conv, fuel pump, FMIC, PFC, splitfire coils and heavy duty clutch and redline gear oil. I put sydney kids susp package in aswell. Wheels are 33 GTR with federal 595 SS tyres, backs are 245/45/17 and are brand new, fronts are 235/45/17 and have about 70% left. It has factory sunroof and ABS. The rear wing i don't know what it is but looks like a wide GTR item. Factory side skirts, rear pods and front lower lip. Drivers seat has small rip/wear in usual spot.
Car is set on 12psi high and 7-8psi low. At 10psi it made 180rwkw at SAU dyno day, it was tuned by Adam at JEM where when running 12psi it made 196rwkw, and if anyone knows Adam this tune is very safe and actually it has made over 200rwkw . I absolutely love this car and don't really want to sell it, but the wife says sell it. It is serviced every 5000kms.
https://www.sau.com.au/forums/topic/220653-1997-s2-gts-t/
You are selling it because your wife said "Sell it"? :D
Good luck with the sale mate.
That and with her getting a company car, we don't need two cars and i'm also looking at a company car soon and if i get it i'll be going down the GTR route.
Thanks mate, the way the market is i need all the luck i can get.
https://www.sau.com.au/forums/topic/220653-1997-s2-gts-t/#findComment-3891308
  • 1 month later...
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
