Hey Guys,
I have a 1990 R32. My speedo all of a sudden dropped out, and my hicas light has come on and the power steering is heavy. when you first drive the car for the first 5-10 mins all is good, steering is fine, then the light comes on and the steering becomes heavy. i have checked power steering fluid and topped that up. Just wondering if anyone knows what the problem may be....... the speedo esp is rather annoying!
Cheers!
Pammy <Queen R32>
Sounds like you've snapped the little needle on the end of the speedo cable where it goes into the back of the dash.
Exactly the same symptoms as when mine snapped. You can get a new one from Nissan but I can't remember how much it cost, don't think it was too outrageous though :P
Thanks for that!!!!! And would that make the hicas light come on and the power steering not work properly? If i were to call nissan and ask them for the needle on the end of the speedo cable that goes in the back of dash will they know what im on about? haha
Thanks heaps!!!!!!
Also, do you nkow where io would go to get it installed?
Thanks heaps!!!!!!
Basically the HICAS light is coming on because the HICAS ECU is throwing up an error due to lack of signal (it gets a road speed signal from the speedo which then sends it to the ECU). Our cars also have speed sensitive steering which kicks in at about 80kmh (light steering for low speed and parking etc, heavy steering for high speed etc), if it doesn't get a road speed signal or a steering angle signal, after a few minutes it will throw up an error and your steering will go heavy.
Unfortunately you can't just buy the needle as it is integral with the cable so you need to get a whole speedo cable. Head to Northside Nissan and specify the year and model of your car and they should be able to sort you out, when I got mine they had one in stock so it was all good..
Any competent mechanic who knows skylines should be able to do it. I did mine myself when I put the 25 box and 280kmh dash in.
Good luck :P
Spot on! Cable broken.
Mr Keets R32 had the same problem last week. New cable, all fixed.
Northside is the palce to get it, probably cost around 120-130ish. It will take about an hour to install.
Good Luck
  • 2 months later...
Good luck :O
Hi, I'm having this same problem too.I've tried many times to reassemble the speedometer to the cable but the needle either doesn't contact properly with the meter or the internal part of the cable sank in.Do you have any idea how to secure the needle to the cable? There's also a spring inside the needle..it dropped out initially but I put it back, still won't work.Please help!
Edited by EJD
just one thing though northside nissan only stocks the GTR cables you can use them but they are too long you have to get the GTS-t one ordereed in, i got the gtr one and it works but doesn't look very good under the car
Hmm that explains why my cable is so long.. I was changing gearboxes at the time so just assumed it was a difference in the boxes..
You can get them to order you the right cable though.
Edited by bubba
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
