Hey guys,
So Ive narrowed my car search to either the skyline v35 or mazda rx8
ONe thing going for the skyline is the slightly more reliable history and comfort ...im going for more a cruiser
I prefer the look of the rx8 just, but the reliability problems and fuel scare me a bit
My main concern is the spare parts for the skyline.
I know that some components share are similar to the 350z, but which parts.
IN regards to common problems of the skyline, can they be fixed using 350z parts, or would I need to source the parts overseas and how expensive is it?.
Thats pretty much my only concern, eveything else about the car is amazing.
https://www.sau.com.au/forums/topic/221032-v35-spare-parts/
engine, drivetrain, suspension & braking are pretty much similar. power windows motor the same. oil filter/air filter is easy. exhaust from 350Z can be used but need to have an extension pipe of about 10-20cm because 350Z is shorter.
interior, seat, body panels, headlights and stuff are different - you can get some trims from USA but things like dash, seat, door panel will be LHD oriented and may not fit - keep in mind when ordering body parts - our passenger side is driver side in USA. Otherwise try to get someone with japanese FAST and lookup part no that you need and try approaching local Nissan dealer if they're willing to import the parts for you with the part no you got.
basically for service purpose, if you take it to nissan they should be able to service it. it's the same engine anyway.
for accident purpose just get it fully insured and if anything happens the insurer or the repairer would either have to source parts all covered by insurance. or take the lum sum and find another one. an '03 V35 can be insured for $40k which would be enough to find another one in case of the bad happens. Just don't under-insure your car value just to try to save premiums, I tried different quotes and it only saves less than $100 by reducing a few thousands of coverage, a saving not worth to not getting the higher cover.
https://www.sau.com.au/forums/topic/221032-v35-spare-parts/#findComment-3897065
Excellent advice! I'm insured with JustCar with $2000 excess, if you are worried about excess, just quote a higher agreed value to cover that. In the end it'll only make very small difference to your premium.
https://www.sau.com.au/forums/topic/221032-v35-spare-parts/#findComment-3897514
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
