  • Replies 100
Posted Images
Let you guys know that E.S.T is a streets car crew, we are not accociated with Seductive Motorsport as for they are a car show crew. That why I need to editing my first post in the thread so it was my mistake. sorry.
Cheers
Hmmm.....I might still drive past to check it out
is this cruise notified to the po po?!?!?!????
We will call up with cops and let them know that we doing a charity cruise. Everyone must be on their best behaviour and HOONING will not be tolerated and the police are notified of the cruise, please be sensible.
Edited by -i-b-u-k-i-
if you want to edit your first post you have to report your self and in the body of the report aks for the specific changes that you want and im led to believe moderators should be able to do it
Anyone know where can I editing my first post in my thread?
I need to change it asap.
oh ok thanks steve and i will ask the moderators. So who is the moderators?
Cheers
c'mon pete would be good to get a GTR out there for the first cruz,
plus u would have the coolest car there. (unless a R35 GTR rocks up) (or a Z-Tune)
Lol...Norris, don't try to force people to attend the cruise if they don't want to. Its their choice in whether they want to come or not.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
