A few weeks ago I had to figure out how to remove my turbo. Thanks to the help of people on here I managed to do it relatively painlessly. So I thought I would put up what I did on my car a few weeks ago in a brief how-to for anyone's that's interested in removing their own turbo.
I decided to put it in here instead of Forced Induction Performance because it doesn't really have anything to do with performance unless you're upgrading or something. I did it myself as a maintenance procedure to repair the wastegate so I think it should be here.
Some of you might notice that I had this up on the Overclockers motoring forum, but I decided to pull it out because that forum is too full of tards. (any other ocau'ers please note: this is not a slight against ocau at all, Agg is a good friend of mine).
I didn't do this exactly as listed, because I tried some things and found they were too difficult and so attempted to get in other ways (eg, at first I tried doing everything from the top through the engine bay). This is how I ended up doing everything as best as I can remember it (apoligies for omissions and errors, if you find any please let me know and I'll fix it up).
This all applies directly to an R33 Skyline with a turbo in the factory spot with the water cooling lines installed. I suspect most factory turbo cars would be similar, but make note of any obvious differences between your car and an R33 before going ahead.
Start
1. Put your car in a secure garage or other covered workspace where you can leave it for at least a few days (this is assuming you will be sending your turbo off for inspection/repair).
2. Put the car up onto some wheel stands or ramps, to give yourself easy access to under the car.
3. With the engine COLD or at most, MODERATELY WARM (you really don't wanna burn yourself), remove the intake piping from the front of the turbo and move it out of the way.
Actually I'll just stop right here for a moment. If you want to simply check your bearings for play, just do step 3 without jacking the car up. Once you have exposed the compressor wheel, spin it with your fingers. It should rotate freely without any stickiness.
Push it inwards and outwards to check for axial play, it shouldn't move at all. If it moves even slightly, it needs a rebuild or will need one soon. Move it side to side, it should move very slightly (maybe not at all if a ball bearing turbo, not sure). It should not touch the turbo housing.
4. Remove the wastegate actuator (it gets in the way when removing/replacing the turbo). It's held in place with 2 mounting bolts and a spring clip on the wastegate pivot. The actuator is a round thing with a rod coming out the back. My car has an electronic boost controller which has a vacuum line up to the actuator which also needs to be removed. I'm not sure what cars without EBC's have to control the boost.
5. Put a large drip tray underneath the general area of the turbo. This is for catching coolant only, you won't lose very much oil at all on an R33. Some rags will take care of the small oil loss. The coolant will dribble down lots of places, so be prepared to shift the tray around for the best spot.
6. From the engine bay side, undo the oil and coolant line bolts. The oil line is small small bolts holding a metal jacket onto the top of the turbo, the coolant bolt is large and holds a round coolant terminal onto the side. There are brass washers that you need to be mindful of on the coolant lines, they are very easy to let drop onto the ground. One washer goes either side of the round coolant terminal for when you replace them.
7. From the underside of the car, undo the bolts for the same lines on the other side. The coolant line is on the engine block side, the oil line is underneath. I found the best position to reach was from behind the front crossmember.
8. Move the lines out of the way as best you can, being careful not to pinch or bend the metal.
9. Undo the 4 bolts holding the turbo onto the dump pipe (exhaust). Be careful not to lose the nuts, washers, and gaskets. Especially be wary of something falling down the exhaust, you really don't want to have to fish it out again!
10. Undo the 4 bolts holding the turbo's exhaust housing onto the exhaust manifold of the engine. Be careful not to lose gaskets, nuts, etc.
11. Carefully pull the turbo off and up out of the engine bay. You have to wriggle it around lots, to get it off both the exhaust and manifold, because there are 2 sets of studs on each keeping it in place.
12. If you need the wastegate actuator inspected/repaired as well as your turbo, now is a good time to put it back on.
https://www.sau.com.au/forums/topic/22118-removing-turbo-on-r33-how-to/
  • 4 weeks later...
  • 1 year later...
    • Yep I will use a guide coat after putting filler, I will do it on the whole panel as I'm a beginner so chances I've made quite a few errors. In that photo, I think that was a low spot, I just for example said to pretend it's flat but I will put filler + guide coat after to assess where I'm at. Yep with that picture, the panel is wet as it rained when I took the photo. But all those scratches are completely smooth, I went over it with 240 grit and can't feel it, even with my nail digging into it. I was legit thinking to buy a 2k can and spray primer to see how it turns out but then thought to myself it's going to be a mess doing it haha. Good mention there. Thanks for all that info I think I know what to do next.
    • Prior to laying down the primer, you need to make sure the surface is completely level. For example, based on this picture, I strongly suspect that the areas marked in blue are higher then the area marked in green.  If you spray primer over this entire area, then paint and clear it, the finished result will 100% show the low area. It will stick out like dogs balls. Unfortunately the paint won't magically level out the low areas as you lay it down.  Without seeing it in person, I expect that the green area will need to be filled, then use a guide coat and check that the entire repair area is level with a large sanding block.  With this picture, are you saying that even though you can see the scratches, the panel is in fact completely smooth and flat? If this is the case sure you could prep and paint it as it is.     The picture with the paint you described as blistering, it's hard for me to comment on from the photo alone. It looks like the panel is wet? Dunno, looks strange. Does the panel feel as smooth as glass when you run your hand over it? **** Going back to your question again, generally you would only sand the primer if you made a mistake while laying down the primer.  If the panel is prepped properly and you lay the primer down properly, you should not need to sand the primer.  This wouldn't work - Don't prep the panel. Spray primer and see how it turns out. Sand the areas where the issues appear. Spray more primer and see how it turns out. Sand the areas....... Yeah you'd go round and round in circles getting no where.
    • That's sick, thanks for that, mine has much the same mods on a 400R. I just don't have the heat exchanger yet.   Might be worth a trip down the M1 to Syndey for a tune.
    • Mate , this is the current mods list Current Mods list (Installed) RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler AMS Alpha Performance Full Race Down Pipes ECUTEK tune form TuneHouse in Sydney .(Just over 2k) The car came with HKS - Power Editor but I had it removed for the full tune. I would say if you are using the car for street diving a proper tune would be better.
    • Interested to see any videos of this or on the dyno. Mine currently has HKS secondary cats i am undecided if I want to remove them. What did it set you back to get the tube done? And what mods have you got to get that power? I was looking at a racebox flash tune but maybe a proper tune would be better if these guys are good.
