  • Replies 92
i dont trust any workshop with my car no matter how recognised they are, refer to the dude who's s15 got written off when he went in for a service. they also charge an arm and a leg to tune your ecu which takes maybe an hr. pfft
Bl4cK32 - I agree and I never would have taken my car there either. But John is working there now because his brother owns the joint so I'd only take it there to see him - definitely no one else!!! Thats why I said "make sure you ask for him though!!" :D
Hippy - I got into Tilbrooks with no trouble. Why such a long wait?? I personally didn't even think they were that good, but just my 2c!
Turbo Tune would be my pick also,
John Keen has leagues of experience on any of the other tuners mentioned above.
-He has built and tuned V8 super cars for the last ten 10 years.
-He will happily provide warrenty on the Cars he Dyno tunes!!( I don't know a single other tuner who will back up there work like that)
-The Dyno he uses is the newest and most accuate hands down in Adelaide(2WD + 4WD) It has sperate cell correction which means that no matter the temp or realative humidity you will always get the same power reading.
Yes other tuners might get more power from your car however how long it will last is another story, and when it does go bang.....do you think they will say" no prob, it's under warrenty"
John is really good and he'll know your car's limits - he won't tune it so stupidly that it blows up or anything like that.
He tunes my b/f's cars and he got an extra 27kw out of one just by tuning it. He said it had heaps more potential but he said he didn't want to go stupid or it would just be too impractical. He is really smart and knows his stuff.
I was at Turbo Tune one night when he was tuning a 200sx my b/f's bro was driving at the Clipsal 500. Gained stacks of power, from bout 160 to 180 something kw just by tuning and dyno running it once.
Steve: Martin left Tilbrooks cos he didnt get along with the new guy from subzero. They had an arguement over John Munros drag car ( the sub zero guy said that munros car needed a microtech ecu whereas martin believes the apexi power fc is fine) anyway he got pissed off and left.... Thats wat i was told, but Martin, however im sure John would know the full story.
Hmm im considering seeing Turbo tune.... So if they up my boost and something goes wrong, they will look after me? Sounds too good to be true.
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
