  • Replies 155
Posted Images
that reasoning makes not sense when coupled with the fact your buying an NA skyline lol
It does make sense... he would only buy a S15 if it was turboed. He didnt say anything about buying a skyline only if it was turboed... Maybe he likes skylines alot so he doenst mind, but doesnt like S15's enough to get a non turbo version.
+1!!!
I'd go non turbo skyline than non turbo s15, however most ppl would go s15 i think
the 2.0 will totally rape the 2.5
lol yes it surely would.
in alot of cases 2.5 doesnt own 2, that is definitely one.
autech S15 has as much power as aus delivered s15s, which in a light shell its alot quicker then a non turbo skyline
Yes.. its chocka block full of goodies..
I think if I had my time again.. id buy an NA s13 and spends the diffrence on mods.. strip and cage.. ghetto
But i dont think that was what MR XTC wanted to know.. just a passing thought..
Sorry.. but if I had the choice.. NA skyline vs NA S15.. I wouldnt be driving a skyline..
you and me both! shame they are so rare though...
swap the S13 with a 240Z and you've got me sold
i would still choose the skyline becuase im not a fan of the sound of a 4 cyl. the skyline engine sounds much better. if i went 4 cyl id only go subaru becuase they sound really nice.
i know its a silly reason but i like to have a nice sounding car that i like i dont care if there is a faster car out there i get something that i like not what everyone likes.
there are other reasons, the autech silvia is fast which is great but i still wouldnt really want it. if i had to have one id go turbo because you have more possibilities for mods than one that already has heaps on it. even though it would be cool to have a really fast N/A car.
autech s15, i happen to of got one importted last year,
pearl white autech
ZOMG that car is very impressive man,
i raped the type R
i raped australian s15
and trust me i kept up to the turbo skylines
The car is a very nice car to have, i luckily bought that car when the restriction weren't such a big deal
i sold it off, and again got another skyline.... its weird... frekn skylines ! ahahahhha
sorry to hear abotu your loan decline... why do stupid things keep happening just before you buy the car????
take care guys!
anyone heading up to KK at liverpool on friday?
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
