Model: 1989 R32 Skyline Gts-T
Milage: 166XXX
Transmission:Auto
Colour:Custom Orange with gold pearl
Complied?Yep
RWC supplied?Not Needed
Currently registered?till 17/08/08
Price:15,000 ono
Contact:Pm or Phone 0402237079
As Much as it upsets me to do so, im putting my loved 32 up for sale. Need to get out of debt and start saving for a house..
Ive had the car for almost 2 years, being the second owner in Australia. Car runs perfectly, been a pleasure to drive.
Details are:
1989 Nissan R32 Skyline Gts-T
RB20DET Silvertop
166,***kms
Auto
Exterior:
Custom orange respray with gold pearl, done by M & C Doyles
18" Starcorp Impuls, 18x8.5" Front and 18x9.5" Rear. Front tyres brand new 1 week ago, rear still have decent tread.
Trial Front Bar
Vertex Sideskirts and Rear bar
Viva Garage N1 style fibreglass vented front 1/4 panels
Engine Mods:
Intercooler
3" full exhaust system
pod filter
Makes 121rwkw on 10psi
Interior:
Vinyl Retrimmed Sparco front seats
Isotta Sports Steering Wheel
Oil pressure, water temp and boost gauges mounted in top din of stereo bracket
Pioneer Head Unit
DLS 6" splits up front with 6x9's at rear in custom parcel shelf.
Cyclops Top of the range Alarm and Immobiliser
Am looking for around $15,000 ono or possibl trade for something small & non turbo, with cash my way.
Edited by *flick*
https://www.sau.com.au/forums/topic/221657-custom-orange-r32-sa/
awesome car, has been well looked after by flick and her co pilot.
hope it stays in sa, whoever snaps it up will probably never be able to wipe the grin off their face. :wave:
best of luck with the sale flick.
Thanks guys.
Car is in getting $1000 work done under the bonnet. All new hoses, Cooling system flushed and cleaned, with new coolant. Just had a wheel alignment.
Will part with car for $13,000 even!!
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
