ok, I'm soon going to be buying a r32 rb20det front cut to transplant into my silvia.
What I want to know is, what do you guys reckon I should do to the engine before I put her in.
I'm thinking
oil (obviously)
coolant (obviously)
gearbox oil
hose clamps and maybe hoses
timing belt?
Also, what is the textbook method for "flushing" the cooling system and lubrication (oil) system?
How involved is it to change the timing belt and re-set the timing properly (I don't want my valve's hitting my piston's :))
Also, people have recomended to me that I change all the belts, but I don't think I will because if the power steering, air cond. or alternator stop working, I'll know about it and it won't cause any damage except for the cost of a new belt and/or battery. Is that right? The oil pump and water pump are driven through the timing belt aren't they?
https://www.sau.com.au/forums/topic/2217-engine-transplant-servicing-advice/
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
