Turbo smart bov type2 $90ono
R33 crank angle sensor $70ono
R33 throttle position sensor $50ono
R32 charcoal canister (big one) $50ono
HKS electronic boost controller $350ono
R32 injectors X4 $50
R33 type m (series 1) spoiler $70ono
R33 HICAS rack $60ono
R32 turbo pipe $20
pm me happy to post
Edited by SKYYLINE
https://www.sau.com.au/forums/topic/221702-r33-some-r32/
price drops
Turbo smart bov type2 $70ono
R33 crank angle sensor $60ono
R33 throttle position sensor $40ono
R32 charcoal canister (big one) $40ono
HKS electronic boost controller $300ono
R32 injectors X4 $40
R33 type m (series 1) spoiler $50ono
R33 HICAS rack $50ono
R32 turbo pipe $20
https://www.sau.com.au/forums/topic/221702-r33-some-r32/#findComment-3927175
R33 crank angle sensor $60ono SOLD
R32 charcoal canister (big one<>epa friendly) $40ono
R33 Rear HICAS rack $50ono
R32 turbo pipe $20
Edited by SKYYLINE
https://www.sau.com.au/forums/topic/221702-r33-some-r32/#findComment-3936872
price drops.... and if its not cheap enough make a offer
Turbo smart bov type2 $50ono
R32 charcoal canister (big one<>epa friendly) $35ono
HKS electronic boost controller $250ono
R33 type m (series 1) spoiler $40ono
R33 Rear HICAS rack $40ono
R32 turbo pipe $20
Edited by SKYYLINE
https://www.sau.com.au/forums/topic/221702-r33-some-r32/#findComment-3941855
price drop to clear this stuff
Turbo smart bov type2 $40ono
R33 throttle position sensor $30ono
R32 charcoal canister (big one<>epa friendly) $30ono
R33 Rear HICAS rack $30ono
R32 turbo elbow pipe $20
Edited by SKYYLINE
https://www.sau.com.au/forums/topic/221702-r33-some-r32/#findComment-3977418
this stuff still for sale
https://www.sau.com.au/forums/topic/221702-r33-some-r32/#findComment-4006839
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
