Item:MOMO Supercup XL seat
Age:NEW
Condition:NEW
Price:$850 or $900 with side adaptors
To Fit: (What car)Universal
Contact:PM best
Comments:I have recently purchased a MOMO Supercup seat, but dont think i will be putting it in my car.
It size is XL. Its brand new and still in the bubble wrap that it came in.
This seats cost over $900 without the seat adaptors. check on MODYOURRIDE. The adaptors cost over $120 also.
Both the seat and adaptor is made in Italy.
https://www.sau.com.au/forums/topic/221877-momo-seat/
  • 1 month later...
any offers ppl
the seat is just sitting in my room!!!
and it comes with the side adaptors and now has a seat rail to fit an R34 both GTR or GTT
So i will sell everything ready to bolt into your car for $900
Cost me over $1100
https://www.sau.com.au/forums/topic/221877-momo-seat/#findComment-4035619
If this MOMO seat is anything like my older Momo seat they are very comfortable for the larger frame Aussies, nice and rigid and also the material on my seat has been very durable with no tears, balling etc etc.
I am tempted to buy this as mine have head restraints and now that it sees more road kms isnt practical. Good luck with the sale...they are a good seat
https://www.sau.com.au/forums/topic/221877-momo-seat/#findComment-4074815
got any measurementsof the seat.... as in the inside area for the ass n shoulders etc?
cheers
[/quote
Its a XL size so i dont really know the exact size !!!
But i will try to find it up on the net!!
https://www.sau.com.au/forums/topic/221877-momo-seat/#findComment-4074991
No its a good seat!!
Its BRAND NEW still in the bubble wrap it came in!
They are a good seat
https://www.sau.com.au/forums/topic/221877-momo-seat/#findComment-4075000
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
