OS GIKEN TWIN PLATE
Age: 12 MONTHS SINCE REBUILD
Condition: FAIR CONDITION
Price: $300
To Fit: OFF A R33 GTST S1
Contact: DAVID VIA PM OR 0402 471 363
Comments: CLUTCH COMES WITH OS FLYWHEEL. SELLING DUE TO CHANGING MOTOR AND GOING TO AUTO. PREFER SYD BUYERS
https://www.sau.com.au/forums/topic/221922-os-giken-twin-plate/
