Make: R32 GTR
Model: 1989
Milage: 61 XXX
Transmission: Manual
Colour: gray
Complied? YES
Currently registered? YES
Price: $28 000
Contact: PM
i no longer want to keep my GTR
i dont have enuff room for it and i dont have enuff time to enjoy it so im better of selling it
car is very well maintained ive spent alot of money on replacing parts which didnt need to be replaced just to keep it well maintained
Engine
HKS step1 camshafts 264/264
HKS adjustable camgears
HKS inlet manifold gasket
Gates timing belt
custom stainless heat treated billet CNC machined oil pump
R33 RB26 crank shaft
external oil return lines from cylinder head to sump
Garrett GT35R Ball Bearing turbo
TiAL 44mm external wastegate
screamer pipe
custom steampipe Manifold
custom dump pipe + front pipe
hi flow 3inch cat
X force cat back exhaust system
115mm intercooler
custom aluminum intercooler piping
custom intake pipe
custom air box
greddy blow of valve
custom catch can
aluminum radiator
Fuel System
SARD fuel reg
SARD 800cc injectors
Bosch 023 fuel pump
Management
Power FC D jetro
Power FC commander
Suspension and Brakes
cusco coil overs with swift springs
hicas lock bar
EndLess VN front pads
EndLess brake fluid
DriveTrain
HKS triple plate clutch
HKS fly wheel
Interior
Recaro SR3 Passenger & Driver side
Blitz ID3 boost controller
Gizzmo shift light
Defi-Style 3 Gauge Din Dash
Defi style boost gauge
Greddy remote control boost switch
Exterior
CR KAI 18 X 9.5 +12 BRONZE
Nismo side skirts and Nismo rear pods <----- not fitted yet
6000k HiD headlight kit
POWER: 316kw @ 16psi
Maintenance
2x cam seal
1x drive shaft seal
2x nissan cv boot kits
5.5L Penrite HPR40 40
1x endless VN front pads
0.5L endless brake fluid 50
1x reverse gear lock-out selector
2x earl's -6 adaptor
2x blanking cap
2x 16mm copper washer
2.5L mobil delvac synthetic diff oil
1x nissan water pump
1x nissan oil pump gasket
1x nissan front crank seal
2x earl's -12 weld-on fittings
1m earl's -12 braided line
2x nissan exhaust manifold gasket
Edited by STR8E180
https://www.sau.com.au/forums/topic/221973-1989-r32-gtr/
standard internals?
every thing listed is every thing done
standard piston's and rods if thats wat ur asking for
internal upgrades are basic the bottom has
billet cnc machined oil pump
brand new bottom end bearings
pretty much just freshened up the bottom end just for that extra piece of mind
the cylinder head has
hks step 1 cam shafts 264/264
hks adjustable cam gears
gates timing belt
all new geniune nissan oil seals
Edited by STR8E180
https://www.sau.com.au/forums/topic/221973-1989-r32-gtr/#findComment-3927722
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
