in regards to the oil an filter change for R33 skyline i just needed to know a few things
like the viscocity
full or semi synthetic. advice on types of oil brands an what is the most recomended,
how many litre's to fill, especailly for an rbdet 25 / 2.5 ltre engine
and last but not least what type of oil filter will i need to be using, for the nissan skyline R33 Gts-t 2.5 ltre engine.
https://www.sau.com.au/forums/topic/222001-r33-oil-changing-an-filter-change/
if you want a decent oil go,
red line
royal purple
elf
all in there fully synthetic
the cheaper but alright ones are
castrol edge
mobil one (gold bottle)
depends on your driving and engines usage and its km's
safe to say use a 10w-40 if you are under 100,000km
oil filter you can get from nissan for $12 and the engine with the filter on is 4.2 liters to fill it
red line
royal purple
elf
castrol edge
thnx very much, appreciate it.
red line
royal purple
elf
castrol edge
In regards to mobil 1 , there is two gold bottles from memory.... 10-30 and 0-40. Get the 0-40 one.
And with the oil filter, i would just get ryco from a local repco or the like store. THere about 10 bucks, save the hassle of going to nissan... and they are just as good if not better then nissan filters.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
