So I'm driving to my girlfriend's house tonight. I'm accelerating up a rather steep hill in third, when at about 3000rpm my car suddenly loses all power. It's like it hit a rev limiter at 3000rpm. The exhaust starts making a loud, rapid popping noise and the car shudders slightly.
It scared the shit out of me. The car drives fine otherwise, but you push it even slightly and the same problem occures.
Any idea what's going on? Thanks.
https://www.sau.com.au/forums/topic/222178-severe-power-loss/
Sounds like an ignition problem. Check your plugs/leads/ignition coils.
There is also a possibility you could be using low octane/tainted fuel (mate of mine had a similar problem with his Maxima as you described, he drove it was nearly empty and re-fueled - problem went away).
could be your viscus hub cluctch is f**ked happend to me kinda same thing ...if you havent converted to a electro fan allready check when you cars off and cooled down if the big fan blade at the front of your car spins with ease if its stiff thats your prob if not dunno bro hhaahh. good luck
hmmm.. wot about your afm? if the plug has come out doesnt it barely get over 3 grand? and its "like theres a rev limiter at 3000rpm"
just a thought...
cuz if the car has gone blind in the amount of air its sucking in, I believe it would cough and splutter or possibly even shudder as you said... and the poping may be the fuel ratio getting too rich/lean... cuz the car has gone off the standard air/fuel maps and has gone crazy:P
Exact same thing happened to me,
RB25DE issue.
Spark plugs and Coils are your best bet, the car will shudder non stop as soon as you hit over 2500 or 3000 rpm.
It happened to me last week and freaked me out, got new platinum sparks and splitfire coils.
Works a treat !!
MRXTCZ
Plats were provided by DRC in Greenacre man, his a good bloke, Gil's his name director of DRC.
I called him up basically after telling him ive been reading and told him what the symptoms were, and his like yup. Sparks are gone, and known hassle is coils, one of fix !
I was like hektik!! i bought the coils, and he supplied the plats and full service.
Anyways, Kez, trust me bruh, when u goto ur mechanic and just get ur sparks done, then find out it doesnt fix it, then you gotta go hunt down splitfire coils, then go back to him and get charged again to get them into the RB25, its a mad headache ripping the top end off to just get into the god damn sparks and coils -.-
I was smart though, when i took it to DRC, i told Gil i need the car in 2 hours, he got 2 mechanics to work on it, and was done in less den an hour and a half. ;) sweeettt!!
Trust me, you wanna go the full 9 yards once your in there, so might aswell mod it now, and tick that one out of your lil Holy Mod Book!
But yeah, i saw a coil replacement guide on here, just a few threads below this one, you COULD do it yourself and save the labour costs, but in my opinion i would just get it down to a garage, not a normal petrol station garage, take it to one that knows their S**T bout' imports.
MRXTCZ
P.S Hahahahaha Cris!! THE MAN OF THE HOUR !! :)
Edited by MR_XTC
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
