i dun want to enter my car because its all show no go at the moment, dont want to get teased lol...
so what does that say about my car then?
mine is all show and no go. im happy to admit it it.........but hmmm.......ive got 10 trophies under my belt funny that...........
the whole all show and no go is a but over rated i think.
my 2 cents.
  • Replies 260
my 2 cents.
i dont have show or go, but cara convinced me bahahaha
once the kit is on damo there will be show and when John has finished with her at least she will have a little bit of go too :D
well EBC at tax time, will be a lil bit more go at 12psi. and contemplating painting my rims the same colour as they new rays Gram Lights 57D's, either fluoro orange or yellow :thumbsup:
you do that and i will totally dis own you from the display! :D keep them white they look good as they are
wow, so last year, people were asked if they want to enter, this year its thrown open to anyone and no takers? Yet everyone cracked the shits last year when it was more of a 'chosen' kind of thing, where are you all now?
its like taking the toy away from the baby :happy: only wants it when it can't have it.
petrol aint getting any cheaper so maybe there cutting back on overpriced shows to save some $$
u should change it to a selected event
and then wen u select certain ppl other ppl will whinge and then u just say ok u can go in hahaha
my solution
only two months to go nathan, so i guess its now or never.
u guess no one wants to take the pressure of organising the event, including me, i have never dealt with such an event, i have only been part of them.
if it was to get off the ground, ill be part of the organising comittee, and enter my car, but cant do it alone.
there is interest, but people are not sure what to do., me for one!
this is the last chance for all you people that want tp represent SAU in autosalon 08, MAKE YOURSELF HEARD!
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
