  • Replies 260
come on adam, you know you wanna put your gtr in...
all we need BEFORE 25 july is the intitial $80 entry fee..
we have time to discuss, and save for the extra features in our display....put away 10 bucks a week, its easy.
we are looking at holding a meeting next friday evening, flick will post details soon-ish.
all that are interested in being in the display, ate expected to show.
ARE EXPECTED TO SHOW.
its 90 bucks standard entry, or 80 as part of club display, to be classified as club display we needed atleast 6 cars, we have 7. including a 34 v spec...nioce
Edited by craig R33
You will have to ask guy (4door sleeper) as he is handling all the pms of interest, but he told me last night he had 4 in, plus today i got another 3, my mates aqua 32, 34 v spec, and kitted/slammed/huge wheeled (blinged) aristo.
so there is quite a diverse range so far between power and visual factor.
hmmmmm still missin 33 gtr though...hint hint!
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
