  • Replies 260
^^ sounds good to me....al long as ther is parking avail? meh, ill take my company car and park in a loading zone lol
but yeah, auzzie pizza house sounds good.
now, whos coming?
i need to know whether i need to print more entry forms.
is the R31 mentioned a GTS-R or lookalike? cant wait to see the line-up.
what is it like getting into the car park there? i might pull the DR out the garage this weekend but i dont want to scrape out my front bar again :)
hmmm and which display are you with again :)
lol. i committed early to another display, way before there was even any talk of an sau display. i was thinking that some of the best skylines in adelaide would be there, my car is NOWHERE near that.
Mine is entered.... although with the R31 club.
Lets see how the candy painted show ponies like matt colours, roll cages, obscene offset wheels and 1 inch ground clearence. :)
Id enter with SAU, but I think my 31 will look out of place with the 32/3/4's..... and with the 31 club will be right at home.
pitty no SAU this yr by the looks. were did every one go from last yr???? alot of tears last yr an then you giv them the chance this yr an they dont want it
an as for a toyota on a nissan stand wtf guys autosalon is a comp an ur entering under SAU which mean SKYLINESaustralia so ull need all skylines in ur line up to make a stand that will look right dont just make up numbers for a cheap entry thats dumb.
yeh theres members on her that dont own skylines anymore or never have, an yeh there welcome (least i hope i still am) but wen u dont have a skyline u shouldnt enter under the sau banner
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
