hey guys i was coming home from my ice hockey game tonight and saw a white R33 crashed on south Rd before sir donald bardman Drive it looked like the person driving mounted the medium strip and hit a sign on the other side of the road. a ride off for sure :D hopng they had insurance....
hope the person/persons are ok. And hope it was no one from here.
did any one else see this?
Edited by smiddidR32
https://www.sau.com.au/forums/topic/222384-r33-crash/
I just drove past there now...didnt see anything :S
https://www.sau.com.au/forums/topic/222384-r33-crash/#findComment-3918766
still not nice to be a seagull on another man's misery
no ones been a seagull at all im not chasing anything but the fact of the matter is if the car is a write off it will end up as parts either buy the owner if its not insured or by whoever buys the wreck ie wreckers at the auction .
that means more parts for the rest of of us
https://www.sau.com.au/forums/topic/222384-r33-crash/#findComment-3918855
