these are the items that are available :
HKS FILTER with adapter for rb25det/
Malpassi fuel regulator/
FET Turbo Timer + plugin loom for R33 s2/
Nolethane Front Castor Rod Bush Set R33 s2/
Thermal Flex Turbo intake pipe + intercooler etc 3" size/
Custom Cusco Coil Pack Cover suit s2 R33/
Standard turbo intake pipe for rb25det turbo/
ARC blow off valve/
standard R33 s2 Brake lines/ front and Back
cheers
Allan
  • Replies 66
Hey mate ho much do you want for delivery to melbourne 3178 for the Nolethane front castor rod bush set.
Cheers.
PM Sent
Bump need these gone
bump
no time waister's please sick off ppl saying there interested then i go out weigh it for postage then no call pm or anything.
dont waist my time thanks.
sorry to rant on.
All items still available.
