  • Replies 73
Posted Images
just under 5 months til i can kiss these suckers goodbye *does a little dance, woohooo!!*
you know this will confuse the shit out of the Po'Po
coz there will still be kids on green p's with turbo restrictions etc etc and kids who arent... the smart thing would have been to bring all the rules and new plates in at once so it was a simple;
green p's - basically no rules
red p's - your stuffed if i see you with any passengers or a snail or past midnight lol!
the beauty of living in queensland and getting your license 3 months before the p plater laws come in to order. i dont hav eto wear p plates, i can drive any car i want and have any age of people in my car at any time of day or night its swwweeet.
but i think i could have dealed with the laws for a year or two
I don't see what the big problem is? Is it just the colour is no longer red so everyone's getting upset? hahaha The rules you picked up when you got your licences still apply, no other restrictions apply unless you've lost your licence altogether.
I see having green Ps instead of the reds when they come in can only be better for us. People with the reds will draw the attention away from us because they're less experienced and hopefully the police will pick on them more. :(
VicRoads should've made things a little more clear though. A lot of people are taking this 'you've now got green P plates' thing all wrong. They think they've got new restrictions etc.
You should get it sent Basti either should of got it today or latest tomorrow. its sent out by vicroads in a big green envelope lol
next cruise to vicroads!! lets make pictures with red p plates in the roadworthy checking section!! :(
Whered you get them from?
I got my p's like 2 months ago and like 2 weeks ago I got this letter about new laws to do with L plates, nothing about P-plates lol
Yeah they're swapping the colours to match NSW, they have more restrictions on red and less on green...
Edited by 1337
im a bit confused im off my p's in August (cant wait) does that mean they will be sending these green ones out to me as well just to have on for a couple of months?
yep youll have to put them on from July 1st 2008.. for every p plater who got license before 1st July 2008 will have them until you get your full license mate
thanks for the info. i better get mine soon cause im not rushing out to buy them at all, especially just for a couple months. they are great at telling people whats going on, do they expect people to go to there site all the time cause i didnt have a clue that this was going on.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
