Hi all, just got a new clutch put in.
Its supposed to be a heavy duty kit so i guess that would mean a higher clamp load
But the pedal is lighter then it was with the stock clutch
So now i'm confused because i'm under the impression that heavier clamp means heavier pedal
I have a suspicion that im wrong so can anyone confirm that i am?
No a heavy duty clutch just means there's more 'meat' to wear off. You pressure plate is what changes the clamping power of the clutch and therefore pressure of the pedal. The pedal will still feel the same
Correct me if i'm wrong anyone
100% wrong mate.
A heavy duty clutch can mean various things
- more aggressive clutch material
- high clamp load
- etc
But due to new technologies, H/D clutches no longer mean heavy clutch pedal. If fact you have to specially order a clutch if you want that heavy clutch pedal feeling, from most good brands anyway.
Is the clutch more "bitey" than the std clutch you had?
Are you able to "ride" it as much?
100% wrong mate.
- high clamp load
- etc
Ok sweet thanks for the info, I've never looked it up or had it explained to me. That was just my understanding and was obviously wrong. Was just going off my experience, in my old rx7 i put a heavy duty clutch in cause my stocker was slipping but the new one felt exactly the same and still slipped anyway....brass button after that!...even that was pretty light under foot, but never, ever slipped :(
100% wrong mate.
- high clamp load
- etc
good call but i got some to add
Also the pivot points on the fingers of the pressure plate can also make it lighter . well actually this infact sets how heavy the clutch will be. less pivot on the fingers (pivot ring toward inner on pressure plate fingers will make it heavy,) a heavy duty clutch will have more clamping force but your thrust bearing might have been low on grease etc adding to the heavy clutch,
i have a heavy duty clutch holdin 340 rwkw and its as light as a feather but in saying that i had it alterd, and i added a bigger slave,
cheers.
100% wrong mate.
- high clamp load
- etc
The new clutch definitely has more bite in it, but my old one was down to nearly bare metal so yeh.
I can ride it just like the std one i suppose, haven't really tried coz i'm still wearing it in
The take up is closer to the floor now and its alot easier to take off since i got a lightweight flywheel put in as well
Basically let the clutch out and throttle at the same time and off you go
I guess i won't know if it will hold the power until i give it a bit of abuse, i'm just trying to get my head around the softer pedal
cheers.
GREAT POINT!! Spot on.
Not sure how i forgot that.
I had a twin plate Exedy clutch, that had a very light pedal feel but was way too bitey and overkill for my stockish set-up. After a year or so i got fed up with all the stalling and sold it to a mate that was making more power, at the time. When installed in my car, my mechanic fitted a smaller "pivot ring" to match the clutch. When i sold the clutch to my mate, i did not know this or had the pivot ring and he just fitted the std size ring, this made the clutch pedal at least 2.5 heavier. Luckily for me a friend drove my car with the same clutch and then drove his and commented how damn heavy the clutch felt in his car.
A smaller pivot ring pushes the pressure plate fingers closer towards the middle, closer to the edge of the fingers.
Well thats good to know for next time I change the clutch.
I don't think my mechanic would have changed something like that without mentioning it to me so I guess it has no bearing on my situation
So all i can really do is give it some grief and see if it holds?
it depends on your clamp load on the pressure plate..
my HD feels so much light to another HD in another car..
so yeh
But clamp load only effects pedal feel slightly, the pivot point is really the main factor. But there has also been great developments in making heavy duty clutches have a lighter pedal feel, yet have a larger clamp load.
PS: A lighter flywheel actually makes it harder to take off. After my Excedy twin i purchased an Xtreme single H/D and a light weight flywheel, another mate also bought the same clutch after driving mine, but kept the std flywheel; his was easier to drive.
My Xtreme H/D held 275rwkw without slip; after 1.5yrs use (weekend car), 1 drag day (6,300rpm launches on drag slicks), a few motorkhanas, dyno days and club cruises it only wore 0.4mm from new (7.8mm). I have only recently upgraded to a Nismo twin plate as i have just built a well spec'ed rb30det and plan to do alot more motorsport. The Nismo Super Coppermix is an awesome clutch, the most comfortable one i have driven to date and is the most strongest (HP rating) one i have owned.
I know in theory a lightweight flywheel is supposed to make it harder to take off but for some reason mine is just as easy to take off with, if not easier then with the standard gear.
I never felt the flywheel before it was put in though so it might not be a super light one
Edited by r32woohoo
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
