Hi all,
About to change the timing belt on my R33 GTS25T. Have most of the details sorted out (part number, tensioning, torques etc), but one question before I embark on the job:
Q: Do you really have to remove the crank pulley to get the lower belt cover and belt off?
If so, how do you lock the crank in position to undo the f*%# big nut, and is a special puller required? What mega torque does it then need to replace?
Thanks in advance for any info, Peter.
https://www.sau.com.au/forums/topic/22325-diy-timing-belt-question/
u need 30mm socket and a big bar or u can use the starter to do it for u ( put socket in place with bar and kick the starter as it hits the rail it will undo make sure u cut the coils off so it wont srart ) then u need a puller to pull it off it will be very tight .
if u do it yourself make sure u know what u r doing cause u have to time it right and also tension it right . if u dont have a workshop manual i can help .
u also have to torque the tensioner pulley with a torque rench
u must have it in gear and handbrake on !!!torque for the big bolt is rb25 and rb 20 142-152 n-mts , rb 26 446-544 idler pulley and tensioner pulleyfor all engines 43-58 n-mt .
u definetaly need a puller to pull the crank pulley .
if u dont know how to adjust the tension on the belt let me know and i'll post it for u . its very important to have the right tension on the belt and on the tensioner pulley bolt ( if u do it to tight it will break , not tight enough and it will come undone ).
make sure u put back the 2 tensioner washers as the were as well .u need an allen key as well for the tensioner bolt ( 5 mm from memory ) . if u have any problems or unsure dot insall it let me know and i'll post it for u , the 3 timing marks are marked clearly . good luck with it .
it would be good for some one to post how to adjust the tension on the belt?
i thought it was tensioned by the spring in the idler pully?
pics would be good too if anyone has them.
do not adjust an old belt as it will shorten its life .
to adjust the tension once u put the belt in place and the timing marks are right ( all lining up , 2 cam gears , and crank pulley )turn the crank clockwise 2 full turns with the tensioner pulley bolt loose then put allen key in the hole so u acn tighten the pulley bolt ( torque 43-58 nmt )and thats it as simple as that , check the tension by pushing on the belt with ur hand ( just in case u done something wrong ) . important to tighten the pulley bolt 43- 58 nmts , do it less it will come undone do it tighter and it will snap , i have seen them snap cause people do them to tight .
u have to make sure u put the spring in the correct way otherwise it wont work the way it was designed .only use nissan belt as i dont know who makes them for them not to expensive though about $85 trade , aftermarket not much less
i currently work for a belting company and we can get the belts alot cheaper, not nissan, but exactly the same. already matched my old timing belt up. if any one is interested pm me and i will get a price. maybe a group buy and i will get them pretty cheap.
i have used non genuine belts in the past , some last the distance and some dont . the nissan belt is short so it should be o k subarus have very long belts and aftermarket belts just dont last .
thats the reason i wouldn't use aftermarket unless i knew the company that makes the original belt was the same as the aftermarket , its very costly if it breaks it will bend a few valves on the 6 cil rb engines .
my personal opinion , lots of places use aftermarket though .
peter i think i put up everything u need to know about tensioning the belt . when u have it out if u get stuck ill pm my phone number and u can ring me or sms .
when u take the covers off before u take the belt off put the engine on top dead centre that is line ur timing marks spot on .
once the belt is out dont turn the engine ( u may bend a valve or 2 if u turn it hard ).
when all the covers are off loosen the tension pulley nut ( thats the pulley on the inlet side , drivers side )then u should be able to remove the belt u dont have to remove cam gears like some other engines .i think i got the rest on previous posts .when u put the belt on make sure all marks are lining up spot on one tooth out and u r stuffed then adjust the tension then turn the engine a few times ( from crank pulley bolt is easy , insall the bolt temperaly ) to make sure valves dont hit and check to make sure that the timing marks still line up. when u put the crank angle sensor back make sure the o ring is ok ( if not change it )and put a smear of rubber grease( normal grease will do if u dont have rubber grease ) so it will slide in easy . good luck with it peter , regards ,
jerry
Did the job on Saturday. No problems!
Took about 3 1/2 hours start to finish - an easy way to save a quoted $250 labour costs...
Jerry's advice was spot-on, only two minor changes:
1) My crank nut wasn't 30mm, the best fit was actually 1 1/16"!
2) The M6 puller holes in the harmonic balancer weren't very deep - I could only get the puller screws in about 5 or 6 mm - this was still OK.
Total cost was $104 for the belt (genuine Nissan - I couldn't see the point in risking an inferior belt to save $20) and $18 for the puller.
I can recommend you do this job yourselves guys, it is not hard if you're careful, and you get to learn a lot about your engine (belts, water pump, oil seals etc).
Cheers, Peter.
I wouldn't cos a snapped timing belt can destroy an engine. Dum Fik who replaced mine (a workshop) for the previous owner overtightened the idler bearing - snapped bolt 6k later & 1 destroyed engine not under warranty. Only do it if your confident using a torque wrench, and know ALL torque settings.
peter i'm glad u did the job and happy to be able to help .
sorry about the size of the bolt head it must be the RB 26 that is 30mm as for the 6 mm bolts the reason a said to screw them in a fair bit is that u may strip the thread .
now u may have to check the timing with a timing light cause u moved the crank angle sensor .
i always use genune timing belt , not sure of the aftermarket .
i think i get the rb belts for about $80 but thats trade price so $100 sounds right for retail.
BL4kc32 thats a good reason to do it yourself cause a lot of workshops use 18 yo kids to do the work and they dont care , as long as u take ur time and know what u r doing or have someone that knows ( did it before ) u'll be fine . u should never atempt to do it if u dont know though cause as u know u can stuff up ur engine .
cheers , jerry
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
