Hey guys,
i turn my car on, let is run idle...rev it a few times...
after i turn my car off, smoke continue to come out of my exhaust...
what could this be due to? or is this normal?
i parked in parramatta the other night and found some bottles nearmy car when i left.....could some idiots have put alcohol into my muffler?
cheers,
shane
https://www.sau.com.au/forums/topic/223251-exhaust-smoke/
yeah i understand it smoking when cold....but ive quite a lot lately...more than usual.
the car runs fine...
the royal purp engine oil smells a BIT like petrol....is it normal? ive read that engine oil smelling like petrol isnt good.
https://www.sau.com.au/forums/topic/223251-exhaust-smoke/#findComment-3933498
does it leave anything on your kit as it leaves the exhaust? like a blue black, (hard to explain) ill go with marks? if it does then id say oil leak or the motor is burning too much oil. Your oil shouldnt smell like petrol... If it does then im guessing you might have some problems, but its never happened to me. My advice get her down to your mechanic and get her looked at. How many km's have you hit?
https://www.sau.com.au/forums/topic/223251-exhaust-smoke/#findComment-3934298
hmm thanks guys...
i think i may be over-reacting....its just a bit of smoke after i turn it off...it might just be letting out whatever's left in there...
no residue is left on my rear bar....but i'll take it to the mechanic just in case
cheers
https://www.sau.com.au/forums/topic/223251-exhaust-smoke/#findComment-3934370
if there is no residue then thats a good thing, generally when a car has a oil leak or burns to much oil it leaves it behind on your kit. It could just just be struggling to breath a bit and letting the rest out after the ignition is turned off.
The smell of the oil would worry me tho, im not sure what that could mean or could cause. Get it to the mechanic as soon as you can man, thats my advice.
https://www.sau.com.au/forums/topic/223251-exhaust-smoke/#findComment-3934589
oil smelling like petrol is a bit of a worry
take off your oil breathers while its running and see if theres a constant stream of smoke etc comming out, or when you rev whether anything comes out, that can rule out piston rings
how long after car is off does it keep blowing smoke?
https://www.sau.com.au/forums/topic/223251-exhaust-smoke/#findComment-3935689
thanks for all the help guys,
i appreciate it alot.
just did some tests....the smoke coming out is jsut because its cold i think....whenmy brother revs it...smoke only comes out when the zorst starts popping....
BUT i did pick up something ticking towards the engine....sounded like it was coming from the bottom end....maybe sparkies!? but i took it out for a drive....came back 10 mins later and the ticking was gone.
chheeers.
https://www.sau.com.au/forums/topic/223251-exhaust-smoke/#findComment-3935847
haha yeah maybe.
im not sure...but im just happy the exhaust smoke problem is in the clear.
ticking only happens when cold. think i might wait a while and see how it goes. then change it if i HAVE to.
https://www.sau.com.au/forums/topic/223251-exhaust-smoke/#findComment-3936753
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
