Currently Listening To...
3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
