Its an original motor from R33 gts-t
Specs:
-blitz air filter
-hybrid FMIC
-3"exhaust.
-dumpvalve
-6-puck sinter,bear 420hp and 500NM
I want to take out between 350-400 hp. How shall i do that ? How many bars can i push the turbo boost with, and be safe not to blow anything ? And what about gasoline flow ?
The motor have run 85.000 km and never been tuned before.
https://www.sau.com.au/forums/topic/223466-rb25det/
Have a search on the forums, that hp has been acheived heaps of time. Especially look at the dyno result thread for the rb25's, that way you can see the people that have achieved that hp and see what mods it took them to achieve it.
Just to get you started:
Fuel:
-Bigger injectors (something like the nismo 555cc would be good)
-Bigger fuel pump (bosch is good value)
Management:
-ECU (its hard to go past a powerfc)
-boost control (profec)
Turbo:
-Garrett GT3071R or GT3076R depending how far you wanna go
-all new turbo fittings including new dump
The stock bottom end will be fine as long as the motor is in good nick and you get a nice tune done
https://www.sau.com.au/forums/topic/223466-rb25det/#findComment-3937008
Its an streetcar, and i shall not change the turbo. Will use the original turbo.
Have found:
Boost controller: http://www.2kracing.com/Product/2376.html
Injectors: http://phase2motorsports.stores.yahoo.net/pe55rbinkit.html
Is those injectors shit ? Shall i use nismo or hks ?
No i just need a fuelpump, any advices for where i can find good pumps for nice prices ?
https://www.sau.com.au/forums/topic/223466-rb25det/#findComment-3939554
If you will be using the original turbo, you won't be making 350-400hp :wub: You will blow your turbo up before needing bigger injectors. Don't push the stock turbo over 12psi tuned, in my opinion.
Edited by Lithium
https://www.sau.com.au/forums/topic/223466-rb25det/#findComment-3940037
If you will be using the original turbo, you won't be making 350-400hp :D You will blow your turbo up before needing bigger injectors. Don't push the stock turbo over 12psi tuned, in my opinion.
I pushed my turbo to 14psi................... ;)
And the exhaust wheel came out the back :D
btw the standard turbo is only ment to last till 60k
https://www.sau.com.au/forums/topic/223466-rb25det/#findComment-3941308
Specs:
-blitz air filter
-hybrid FMIC
-3"exhaust.
-dumpvalve
easy
Apexi Pfc
Nismo 740cc injectors
Nismo Fuel Pump Or Tomei (both are direct bolt in and will support your power lvl)
Z32 AFm
HKS GT-RS or similar
EBC (i use blitz sbc-id3 but anything good will do)
with the GT-RS you should only need to push 16psi to make 350rwhp
Tune
https://www.sau.com.au/forums/topic/223466-rb25det/#findComment-3941318
As above.
If the car is going to be used for track use then just be aware that at those power levels an internally stock RB25DET WILL be a timebomb.
If driven as a street car though, with a good tune it will stay togeather for years.
who told you this?
I have had 350rwhp in my rb25det with over 150,000km for more than 2years now, have done fair bit of track work and the engine is still going strong
I pushed my turbo to 14psi................... :D
And the exhaust wheel came out the back ;)
WTF? the std turbo will last longer than 60k if its treat right (e.g not over boosted pass 12psi)
https://www.sau.com.au/forums/topic/223466-rb25det/#findComment-3941325
7 psi. Mate, you really are kidding yourself if you want to get any real performance without changing the turbo.
if u actually look hes from norway so theres ur issue lol....
i had my stock turbo at 14psi which is how it came from jappy land with a mines tuned ecu and a front mount.... it was quite a freak for a stock car.......
but u will need a bigger turbo buddy....
https://www.sau.com.au/forums/topic/223466-rb25det/#findComment-3941790
' date='13 Jun 2008, 04:06 PM' post='3941325']
who told you this?
The two blown RB25's I have in the garage :)
But they did take a really solid beating and were putting out 370RWHP @ 14psi so I am not complaining in anyway, they served their purpose and I am now building a forged RB25/30 :)
To be fair the first RB25's condition was basically unknown but it held up for just over a year, and the second one copped a nasty hit to the sump from a ripple strip and the drive back to the pits may have slightly starved it of oil as pickup in the sump was a bit kinked and shit.
https://www.sau.com.au/forums/topic/223466-rb25det/#findComment-3941967
The car im looking at have run 85k, but the turbo is just as tight as a new out of the box turbo when i checked the fans inside.
How many psi do the rd25det pushes when its untouched ?
The car your looking the turbo is untouched
the Ceramic Exhaust wheel comes off................what did you do take the dump pipe off or sumthing
Look at my signature............that is what i need to get 270rwkw @17psi.....
and i limited it at 271rwkw cause i still have standard manifold
https://www.sau.com.au/forums/topic/223466-rb25det/#findComment-3942133
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
