I just installed my FMIC on the weekend
The day after the install had had two joiners blow off when under a full load, So that night i reconnected all the pipping tightend all of the clamps really tight then last night the rubber(stock)90 degree bend which runs from the passenger side of the cooler tore straight down the seam when running around about a constant 10 psi for a couple of seconds.
Has anyone had a similar problem when connecting a after market cooler to the stock hoses.
Where abouts can i get a Silicone 3'' silicone bend from and will it be any better than the stock nissan rubber bend?
https://www.sau.com.au/forums/topic/223557-silicone-bends/
it accually allready has a lip around the edge of the pipe its from Just jap if you are familiar with the kit.
its more the fact that the bend split down the middle(not sure how common it is)
Now i have to cut the front indicators farkin why cant everything just fit
https://www.sau.com.au/forums/topic/223557-silicone-bends/#findComment-3938869
i seen at supercheap 90 degree silicone bends that are heaps longer than the stock piping if i put that on its sure to stay put.*fingers crossed* since installing it on Monday i havnt even been able to boost without something F!@#ing up
https://www.sau.com.au/forums/topic/223557-silicone-bends/#findComment-3939305
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
