Make:Nissan Skyline
Model:R32 GT-R
Year: 1989
Milage:106,000km
Transmission:5 speed
Colour:Gun Metal Grey
Complied?Yes
RWC supplied?No
Currently registered?No
Price:$12,500
Contact:PM or Mobile; 0448072675
Comments / Modifications:Car has the basic mods of 3" cat back exhaust, lowered stiffer suspension, pod filters (has K&N fitted and I have kept the original HKS pods), HKS piping and after market 17" rims. Also has Greddy boost and water temperature guages, along with a Delfi head up display and speed limit cut.
The down side is that there is currently a fault with the running of the engine, please see Gt-r Engine Problem for further details. Basically the car runs but there is either a vacuum blockage or the timing belt has skipped. Other areas are the drivers seat is worn in the usual places and there are screw holes in the dash where the original owner had mounted a boost gauge. There is a wear mark on the rear left guard caused during the shipping to Perth. I will give the new owner an ARC intake box if they want for ease of registration.
Please do not hesitate to phone or PM for further information.
Images:
https://www.sau.com.au/forums/topic/223612-fs-r32-gtr/
Just letting people know that on Thursday the car will be going to the maintenance shop to get timing belt and all ancillary belts changed, also all fluids and filters will be changed. Due to this the price and vehicle status details will be altered accordingly.
https://www.sau.com.au/forums/topic/223612-fs-r32-gtr/#findComment-3947423
Darren, the link to "engine problem" links to the SAU homepage, not to any topics or threads.
Can you list here what the engine issue is.
Thanks.
Brian.
Sorry I thought the link was set up correctly, it should be found here http://www.skylinesaustralia.com/forums/Gt...em-t215959.html
https://www.sau.com.au/forums/topic/223612-fs-r32-gtr/#findComment-3947707
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
