Small drive shaft that runs between both motors on electric chairs(is at the front of the chair)
Reclining Motor cover on passenger side chair
Rear LHD door armrest plastic screw cover
Passenger and driver air vents (large and small ones)
boot lid popper button
bolt to hold down spare wheel
Have a few more little bits and pieces but let me know if you have any of this stuff
  • 2 months later...
  • 3 months later...
spose i should reply to this. sorry for the delay, but you ended up getting your parts hey?
Yeah I did
I still havent fitted them.
Had some issues with new bushes.
I will have to stick up photos as it was a massive problem making nolathane bushes fit on the lower control arms
  • 4 weeks later...
hey mate it has passenger front door missing drive line gone, all other panels, seats and trims, all cloth is badly sun damaged, it has no rear arms or diff or axles, would want about $600 but its pretty much usless unless you have a crashed cima..
give me a sms if you want 0450929227
Edited by E-Z
  • 3 months later...
  • 2 years later...
  • 1 month later...
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
