Hi, Guys
I m just a newbie to own a factory BCNR33, and would like to do some upgrades
Lots ppl said the factory turbo can not go higher than 14psi (16psi is dangerous) or the turbos will be blown
If I modify the turbos to steel wheel one (HKS GT-SS,Greddy T517, R34 N1 etc)
is the factory engine bottom possible to be endured at a boost about 17-19psi to have 300kw atw?
we just ignore fuel system upgrades (injector or fuel pump), focus to factory engine tolerance to discuss
coz I m quite curious to know is factory RB26 really possible to have 500-600hp (at flywheel)?
or it still need to make bottom forges to have 300kw atw (about 360kw/480hp at flywheel)
hope guys to give me some suggestion :)
https://www.sau.com.au/forums/topic/223933-original-rb26-tolerance/
IF.....and I stress IF the bottom end is fresh and without damage, then yes...it will easily handle your required 300rwkw. In fact, 400rwkw is fairly obtainable if you have the correct supporting systems.
If you have no idea on the condition of the engine, then it is really a question of how long until it breaks. You never really know.
some things you can do to determine it's condition are:
Oil pressure test hot
Oil pressure test cold
Compression check hot and cold
check condition of oil and even have it tested by a third party if you wish
And then even if all these items are perfect....a shit tune will destroy it in no time.
You need to make sure your fuel system is up to speed and your tune is perfect.
i dont no wat ur talkin about about those factory turbos not goin ova 14psi lol my mate ran 22psi for 18months finally it blew lol.
you can do article search and ready them, lots ppl suggest do not over 14.7psi (1kg/1bar)
coz BNR32 BCNR33 GTR standard turbo wheel are ceramic made not steel one
i had blown ECR33 GTS25-t's turbo before, the turbo ran over boost at 18-19psi then blown immediately(wheels only) :D
so I m quite careful to face the boost setting evenif the turbos of "GTR" :P
but I still would like to hear more sounds to discuss and learn the boost up setting of GTR :)
No idea what your on about more to the point.
Its been proven time and time again, GTR turbos fail above 14psi
When the turbos fail they can also take ceramic dust into the motor, destroying pistons and the like.
Frankly, your mate was stupid.
Hi, mate
so is health factory RB26 engine possible to endure 18-19psi boost if turbos are changed to a/m steel one?
does the factory fuel pump (190L/H) or factory injector(440cc) must upgrade to suit 360kw at flywheel/motor ?
hope you may give me a little suggestion :P thanks
300rwkw = no problem for a street driven good condition RB26
without upgrading fuel pump and injector can do 300rwkw?
RB26 is a amazing engine :)
coz I just tranfer my ride from SUBARU EJ20
so I had quite lots question about RB26 .... shamed :P
however thanks for your answer :D
RB26 is a amazing engine :D
so I had quite lots question about RB26 .... shamed :D
however thanks for your answer :)
Like to say smart tranfer and welcome to the rb26 world. :P .
No looking back now.
Edited by Rav
coz I found too hard to have 300kw with EJ20 (exhaust too long and lagging to push large turbo)
evenif its big enemy 4G63 is quite easy to have 300kw without lagging (inline engine's advantage so as RB series)
but EJ20 ... sad, you need to pay huge price to have 300kw maybe doulbe/triple up :D
i still love subaru, if i had budget, i will buy one without powering modify(just do handling modifications) to enjoy driving it :D
at this moment I just want to large output monster, i choose GTR to be my partner :)
Edited by shawn.szutu
no you won't get to 300 awkw with standard injectors, fuel pump and air flow meters. But they are pretty cheap to upgrade.
with those, boost controller and steel turbos 300+ is easy with a healthy engine
You can actually make 300awkw on standard afm, injectors and f/pump. Just.
Even tired GTR fuel pumps are capable of supplying fuel for 300. The AFM's are right near max but if you keep the inlet temps down you will make the figures. Also injectors run at approx 85% if tuned correctly and assuming the pump is good.
You would be stupid to leave these things unattended anyway but it's till possible if you want to squeeze it out.
85%? My r32 gtr was at 98% at 290 rwkw!
You can actually make 300awkw on standard afm..
True.. My mech has shown me dyno slips of 350kw with standard afm's. He also says, he finds them better and easier to tune for 300kw applications.
cheers Tomek
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
