  • Replies 123
Posted Images
well im out wont have my car back till monday now :):( will be there and driving next time for sure so plz keep me posted about the next one :cheers:
Sorry to hear Adam - I'll let you know when I am out next. I'm away a lot for work but I will go out at every given opportunity!
Wheres a good spot to get a Cams approved helmet from?
Go for Revolution Racegear or Autosport - but you can use ADR compliant helmets, which generally means you can use most if not all motorbike helmets.
Any helmet with the ADR approved sticker will do Luke.
Depends how fusssy you are on a helmet but you can spend anything from $50 to $1000 for a helmet.
had such a good time today, most fun i've ever had behind the wheel of a car. Farstest lap i did was a 1.25 on my street tyres. Thanks to Andy for the advise, it definatly helped me. The car ran perfect all day, untill i had a look at my front brakes :ermm:
Yay for cross drilled rotors on shitty metal. What brand rotors? I usually only go slotted but have to make note of what x-drilled rotors get fatigue like that....
-D
Was a wicked day - ran a 1:17:01 as the quickest, and no matter what I did I couldn't crack a 16!!! Was great to get back on the track again - Dstroy did really well to keep that beast on the circuit with all the sliding around you were getting!!!!!!
what tyres & pads were you running Andrew and how much oil were you putting in the catch can on average.
I was running a fairly worn out set of RE55s bridgestones on 33GTR rims - 255x45x17. Brake pads are street spec at each end, although I do have AP brakes at the front, braided lines and brake ducts too. I didn't have any issues with oil venting into the catch can - but I never have. I reckon it might have collected maybe 100ml over the course of the day (6x15min sessions).
Can't wait to get out there again!!!!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
