  • Replies 347
i made sure it wasnt tuned to its peak just incase of situations like these were i could run optimax or premium unleaded if C16 wasnt available, ( which it wasnt). ย so conclusion being, i ran 11.5 still with traction problems on prem unleaded, not at its maximum potential. :kick:
Well if you were still able to run the car at full throttle, through all the gears, at maximum load (as per drag racing), with PULP with that tune and NOT get severe detonation, then all you did was WASTE a tankful of C16 last week :(
Why in the world you would pay $150 for a drum of C16, and then get it tuned so you could run PULP???? :):D
Robo,
The amount of wheel spin I was getting was very noticeable from inside the car, the back end was wiggling around all over the place through 3rd and even in 4th, so much so that the commentators made mention of it. The other lads there watching could hear/see it too.
Why in the world you would pay $150 for a drum of C16, and then get it tuned so you could run PULP???? :(:)
i like your comment about "Why in the world you would pay $150 for a drum of C16, and then get it tuned so you could run PULP???? " its an easy answer, ( casue i can)....... :rofl: :rofl:
but seriously at full throttle in 3rd gear it was fluttering a little, but not detonationg, either cause of sparks i changed just befor racing or the tune, will try again soon and see what happends.
Guest INASNT
Robo,
ย  ย  ย  ย  ย
I word man NITTOS.
i like your comment about "Why in the world you would pay $150 for a drum of C16, and then get it tuned so you could run PULP???? " ย its an easy answer, ( casue i can)....... :( :(
I suppose you thought you'd come away sounding rich and powerful from that (because you know.... None of us can afford C16), but instead you came across as a chump who has absolutely no idea about cars or tuning. :slap:
how can u tune a car for c16 but still be able to run pulp fuel when u want and still have no problems.....what comp are u running? who is ur tuner? wreckedhead? (if u tune for pulp fuel u would get to a point where it has reached its limit because of its octane rating.....when on c16 the octane rating is alot higher therefore a more aggresive tune....how do u accomadate for both, without comprimising max power or detonation im just a little confused... ?? plz explain
how can u tune a car for c16 but still be able to run pulp fuel when u want and still have no problems.....what comp are u running? who is ur tuner? wreckedhead? (if u tune for pulp fuel u would get to a point where it has reached its limit because of its octane rating.....when on c16 the octane rating is alot higher therefore a more aggresive tune....how do u accomadate for both, ย without comprimising max power or detonation im just a little confused... ?? plz explain
Exactly.
The car should be tuned with so much ignition timing for C16, it would pretty much grenade itself if you ran it at full noise with PULP.
So basically the tuner doesn't know what he's doing, and wasted all that C16 by tuning such a stupidly large margin of safety into it that wreckedhead was able to run PULP on the same tune, effectively wasting all that C16.
amu,
It's amazingly simple to tune for C16 and then run pulp. It's achieved using an ECU that allows multiple maps. It literally takes all of 5 sec's to switch from the 98RON map to the C16 map to the LMS map to the cod liver oil map (ok so that last one is stretching the truth a tad). I have 4 maps in my handset that I select from depending on what I'm doing. At the drag strip I select my "Valet" map, hmmm.... maybe that's why I can't seem to rev over 3,000rpm!? :)
But seriously... if wreckedhead is using an ECU that has a multi map option then he CAN use C16 and make full use of it. Just as easily he can fill up with 98, select his 98RON map and be safe in the knowledge the timing is not overly advanced (depending on how agressive the tune is). If wreckedhead has only one map to choose from then I'm as baffled as the rest of you!?
whatsisname, amu and Merli:
JETT is running a Power FC tuned by C&V.
Does that answer some questions?
Adrian
Nope.
Unless he has an FC Datalogit with the ability to store and load multiple maps, there is no way he should have been able to use PULP on a proper C16 tune.
i might be a little neive but im not stupid when i had the tune done i made sure it wasnt tuned to its peak just incase of situations like these were i could run optimax or premium unleaded if C16 wasnt available, ( which it wasnt). ย so conclusion being, i ran 11.5 still with traction problems on prem unleaded, not at its maximum potential. :kick:
Interesting. No mention of multiple maps :)
Too many holes that I can't figure out... I'd love if you're able to explain it to me wreckedhead, because I'll obviously learn something about tuning if you're honestly able to make what you're claiming...... work.
ร—
ร—
