hello can you please recommend a street legal semi for an xr6turbo 235/45 17inch rims for the ocassional track work but mostly used on the street , thanks
  • Replies 175
pm sent
You mentioned that you can get Yokohamas.
Can you source Yokohama V103's in 275/30/19 at all?
Cheers
Sorry buddy only the Yokohama ES300, and the dunlop direzzas.
hey mate, got 19" tyres?
pm me some prices on
235/35/19 If you have any in stock.
Thanks,
Steve.
Thanks,
Steve.
u got pm mate
after a pair of either 265/35/18 or 255/35/18
send me your price range, best to cheapest.
thanks
Hi mate,
what do you have in 245/40/17 ?
Looking for a pair of Kumhos or similar, specials, need to be in stock.
cheers
Tony
Hey Tony,
Cheapest i have is either the sumitumo(japanese tyres), or the fulda(usa tyres) for $160.
I have dunlop direzza on special for $210 each.
thanks
Hey mate,
have a look at my 1st post i have them all up with the discounted prices.
If you want something even cheaper let me know i can get something like kumho or cheaper if you want.
need 2x 235/40/17 bridgestone re001 or toyo r1r
Price thanks
Hey buddy, i dont have any of those in that size,,
i only have the bridgestone potenza re750 which i can do $180
Hey mate,
thanks.
mate looking for good tyre but dont need the top of the range.
what can you do for dunlop sports maxx?
what other tyres do you have?
maybe some hankook k104
also do you have hankooks new tyre, ventus v12 evo?
sorry no hankooks,
i can get you kumhos like the ku31, but the toyo specials i have on now in the 255 are the same price as those so i would be going for those instead.
Hey I was wondering whether you have toyo r1r's available. (are they released yet?) there website says late june/july 2008.
I am after 265/35ZR18 93W and a price if you don't mind please.
Thanks
Edited by Gads GTR
Thanks
Hey buddy,
dont have any of those yet, will probably be getting some over the next couple of months.
sorry no hankooks,
hi,
tried looking up those tyres on the net but couldnt find them. are they called vimode?
thanks!!
hi,
thanks!!
hmm, look harder, :)
they are 2 dif tyres, the toyo gu:wn, and the toyo vimode
gu:wn below
gu:wn
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
