  • Replies 58
Posted Images
Why dont you trade up to a nice 2006 XR6Turbo 6sp manual with 22,000kms on it?? I know someone who wants to trade 1 for your GTR:)
Hi mate, I already have a new car, a 2008 FG XR6Turbo.
Thanks for the offer tho. Interested in buying outright? ;-)
Bumps...
Dan
:D
Nice car mate and i no how u feel and it sucks.
you and i both have nice, clean, 300kw to 1000hp GTR's for sale and nobody wants to touch them. Not to mention another bloke on here that has one with less power then mine and trying to sell it at the same price nearly.... and the crappy thing is they are worth so much more!!!!!!!!!!
It sucks.
Seriously do not drop ur price anymore. Don't cut yourself short.
$18500 FOR UR CAR IS A STEAL! whoever buys it at that price will be very very very very very very happy and u should be kicking yourself for letting it go that cheap.
i'm willing to let mine of for Less then half of what the motor alone cost me. forget about the total price of the car!
You ppl need to go talk to ur banks cause you will be ripping this bloke off if you buy his car that this price.
good luck with the sale man.
shame to see you so desperate to let it go at that.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
